St Croix auger feeds continuously, big pile of pellets!
Nuts! -- I was getting ready to solder the triac to the board but my little guy accidentally kicked the power switch with his hefty size 3 and it cracked right off -- here's a picture of the broken switch -- any chance one of you folks would know where to order a replacement switch ? It's the RUN/OFF switch on the right side of the board.
Hello, im calling from Sweden and this is my first post..=)
i found this post and i have also problems with my St.croix aftonbay that is from about 2000 something?
Anyway i have problem with my control board(Analog knob board)
the auger motor turns on too much on low settings, it is ok on setting 1 but when you turn up the settings the auger feeds to much pellets to the stove
if i turn of the 220v to the stove then it seams to work fine for a while?
i need to find out what part that controls the settings 1 to 6?
it is the same control board that you see in this post.
im sorry for my bad english but i hope you guys and girls understand what i write?
Doger..=)
Doggy, maybe your stove is feeding pellets correctly but the air flow is restricted so burnpot overflows on anything above #1 setting. Plenty of helpful tips on this forum to help cleanout St Croix stoves to burn like new again, and worth trying
Thanx for the reply..=)
The auger Control Board have 3 different cycles, one is about 8.5 second and one is about 10.5 sec and 12 sec
cycler can be changed by moving a device that short-circuits between the different pins on the card.
my card is adjusted to 8.5 seconds, that is when the total time the auger motor is running, ie 8.5 seconds between the LED lights up.
at position number 1 will light the LED approximately 1.5 seconds and off 7 seconds and stove works very well.
but then to position 2 so increases the time the light is on for 5 seconds and the time it is turned off is 3.5 seconds, a total of 8.5 seconds
this 5 seconds is to mutch and the stove is heating like like i living in hell,,=)
so i need to figure out why it is on 5 sec instead of about 2,5 sec that should be normal?
stove I have completely renovated a few years ago and I clean it
every week, and disassembling the stove every year and clean the fans and lubricates everything
when the stove was renovated, I built the fan blowers of sliding bearings to ceramic ball bearings, also built the control board with some relays and time relays and more, so the stove is wireless remote thermometer and even a function that starts the heater, when it becomes colder than minus 10 degrees outside, this may I adjust depending on the temperature I want it to start.
I have a heat pump that heats the house to about minus 10 degrees then start the pellet stove automatic, so it can help the heat pump to heat the house, now this is oftopic,,=)
Merry Christmas
Try putting jumper on middle 2 pins, that should be original 11.5 second cycle time and see if heat settings 2 - 5 now work better. Each heat increment should only add half a sec or so, not several seconds! Good luck.
  • St Croix auger feeds continuously, big pile of pellets!
Good Idea, I will try that..:)
but i have a old analog control board, some time ago i fund a manual on my old card on the Internet, but i cant find that info anymore?
i dont know if my card has the same pins like in the photo?
