Yup. I am happy. That will take away stove size question. Now I can work on house with out other concerns.Good deal Sully. I don't think you'll have any regrets. And kudos for your dealer's good service too.
Right ,its not that hard to do. I use from 100 million to 125 million Btus a season,depending on the weather. On very cold days im sure i could use as much as 1 million in a single day. If i had oil heat that would be about 7 gallons of oil. Even with that ,that only equates to 40,000 Btus per hour for 24 hours and my stove is rated for about twice that.This is why it's good to go over previous years' heating bills when trying to size a stove. They will give an indication of the heat loss of the house.
Thats why i dont burn oil anymore,either coal or wood. With the coal its about $8 for 1M Btus. Wood is free.Ouch, about $28 a day to just stay warm, probably only at 68 if that. Got rid of my oil floor furnace right before the big rate increase, I would be crying having to spend that per day on those windy cold days.
One of my stoves is 2CU ft and its in a 600Sq ft Apt.,and it does a good job in the room its in,but no way would i try to do 1000-2000Sf with it.There is a world of difference with a 3CU ft stove. More heat out put for longer periods. Higher sustained heat output ect ect. THe smaller stove in a big space has you loading constantly trying to compensate.Yup. I am happy. That will take away stove size question. Now I can work on house with out other concerns.
The dealer is good man. Like I said before he was upset that it was not giving me what I wanted. Going to be a even swap.
Dealer was just at house. He is a good guy. He said he truly thought it would do the trick. Long story short. We are going to the 2400.
Good to hear, Sully. I'm sure you'll see a big difference in the 2400.
A couple of things I do that i think really gets max heat output from the 2400:
I installed it as far out as I can to allow maximum mass in the room. There's like a five or six inch range, I brought it out as far into the room as possible. Another thing that seems to maximize heat output is pulling the surround off the fireplace about 3/4". This allows any heat that is trapped inside the masonry fireplace to pour out into the room. You can really feel the heat pouring out of that gap.
I hope that is helpful to you. Whether you do these things or not you'll see a big difference in heat output with the upgrade. Glad to hear you have a good dealer. Sounds like he provided a good install as well.
Keep us posted .I would be interested to hear how the new stove performs for comparison purposes. A larger stove can also compensate to some extent, for less than ideal wood and less than ideal insulation levels as well as heat moreeffectively on colder days.Yeah I'd recommend this dealer to people around here
21 inch log is also going to nice.
Well so far since new stove installed there is a huge difference. Generally stove room is warm ( hot ). Other rooms are about 71. That's perfect for us. This stove is a world of difference. I will also say that we do need to work on house. I have been in attic with foam sealing cracks for past few days. Also large hole. Seems when my steps were framed out they draped insulation over a big hole. Big as in the entire run of steps. I used ridged to build a box over it and foamed that up. Installing baffles and hopefully spraying in insulation today.Keep us posted .I would be interested to hear how the new stove performs for comparison purposes. A larger stove can also compensate to some extent, for less than ideal wood and less than ideal insulation levels as well as heat moreeffectively on colder days.
You have to live there and they don’t.
