I'm about to buy a EKO 40 boiler. Our housee has a pressure fire sprknlar system wit a 750 gal tank. Could that be Plumbed in to the EKO system as a storage tank? Ideas much apprecaited and thanks,
That's a new one! I don't know anything about the tanks used for such an application, but if it's rated for more than 30 PSI it should be OK. Can you insulate it adequately?
[qu
That's a new one! I don't know anything about the tanks used for such an application, but if it's rated for more than 30 PSI it should be OK. Can you insulate it adequately?[/quote]
Thanks for anwering. The tank is inside under a staircase - does insulation make big differnece?
If the sprinkler tank is required by building code or if you have a questionable water supply for fighting a fire (such as well water and no local hydrants) don't mess with it. It is too much of a safety issue. There must be a reason why it was installed. Besides, I have seen some tanks that are used for sprinkler applications and they are not rated for elevated temperatures. You should carefully evaluate anything you do in this situation.
You have a 750 gallon tank under a staircase? That's a really huge tank to fit in that kind of space.
An uninsulated tank will create uncomfortable if not dangerous temperatures in the vicinity, not to mention loss of control about when and how much heat to release.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
