My splitter motor quit on me the other month and I parked it next to the shed until I had time to mess with it. I went out today to split wood and it wouldn't start! I tried everything and nothing worked. Then the starter cord broke and I had to rewind the dang spring..... Yup, never fixed it before the snow.
My wife came out and saw that I was ready to shoot the motor and decided to build a shelter out of straw for me so I could be out of the wind. She did a darn good job. I sat there messing with it for a while and was getting a little upset with it so she asked if I would like to unbolt the whole motor and work on it in the kitchen. Of course I did just that. I spilled gas all over the table and a half quart of used motor oil on my pants, but I got it apart and found a bad head gasket, a bad-from-the-factory cam, and some terrible valve shrouding.
I made new head and crankcase cover gaskets from the old standby, cereal boxes. They work great, you know. I reground the cam, since the intake valve never really closed all the way.
The valve timing was also very much not where it should be even though the timing marks lined up, so this was remedied at the same time. The factory "finish" on the cam looked like someone ground it with a very coarse angle grinder. It is now very shiny and smooth.
I had to get the dremel out since the head was off. I unshrouded the valves and reshaped the transition going into the cylinder. I am very happy with he way it turned out. Sorry, no pics.
I set the ignition gap fairly tight because the spark was a little weak when it was outside. Now you can hear the spark when you rotate the crank by hand and it is blue instead of orange.
I put everything back together and torqued the head bolts to 180 inch lbs for good measure. The motor almost flew across the kitchen when I pulled the rope to test the compression. WOW
! I think the thin head gasket and valve that now closes helped it some.
I put oil in it and gave it a tug. It roared to life and bounced half way across the floor as I tried to catch it. I don't think it has ever run this good. I am very eager to put it back into service. It has been running for many, many years with a valve that never closed all the way. There was an extra bump on the intake lobe that kept the valve open just enough. I was amazed that the motor ran as well as it did all these years. That's a briggs for ya.
![Mad :mad: :mad:](/talk/styles/default/xenforo/smileys/angry.gif)
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
