Sourcing a Harman P61a convection blower made by Dayton
Don2222
9,146
Salem NH
Hello
I am looking for a room blower for a P61a, the one in there is made by Dayton. See pic
From HHT > http://www.warmingtrendsstoves.com/harman-p61a-pellet-stove
The Harman spec on their web site for the P61a is:
Room Blower Size: 135 cfm
The trick here is the flange is different than most other pellet stoves. There is no top and bottom on the flange only sides. That is due to a heat shield plate directly above the blower.
If the top flange on the Englander Room blower (140 CFM) was cut off and the two center mounting holes were widened on the inside, it could be made to fit and if so would no doubt work very well.
See pics below.
On the blower TAG 1 is:
Dayton
99080464
115V 60/50 HZ 0.74 Amp 40 Deg C
E47479 12645
Thermally Protected
Dayton Electronics Mfg Co Niles IL 60714
Broan Ref LTRD Serial Number 10N43778R
On the blower TAG 2 is:
Shade Pole Blower
Model: 2C647A
HP 1/70 RPM 1500
Watts 62 Amps 0.65
Volts 110 50/60 HZ
Made in USA
I see this on the web but I would also like the squirrel cage too.
1550 RPM, 0.8 amps, 115V 60hz.
http://www.amazon.com/Broan-Vent-Motor-99080464-60hz/dp/B002NC32PI 0.8 Amps
From CSH but no squirrel cage. I guess I could use the old one.
http://www.cshincorporated.com/product_info.php/products_id/11240
115 Volts
60 Hz.
3.3 Inch Diameter Motor
Motor Length is 2 1/4 inches
1550 RPM
Shaft Size is 1/4 inch x 1 1/2 inches
Two Mount Studs on Front
  • Sourcing a Harman P61a convection blower made by Dayton
I bought that same one from Grainger and it is EXACTLY the same. Other dealers want between 150-200 dollars for that because it came from Harman. That's a BIG savings. I love Grainger!
Agree
This is the new Harman Fasco convection blower for $190.00 that replaces the old Dayton blower.
http://www.stove-parts-unlimited.com/Harman_Distribution_Convection_Blower_p/3-21-33647.htm
What's wrong with the old Dayton blower? Mine is 12 years old and still works great! ! ! LOL
Reactions: PJPellet
