Bioburner
Moderator
Your missing one word to that sentence. Commonly. It usually does not come in small pill form and with a heavy dose of fines.wood alone is not an explosive material
Tell that to the diesel engine and the rocket motors that took man to the moon.Fuel oil dosent explode
Fuel oil dosent explodeTell that to the diesel engine and the rocket motors that took man to the moon.
VaporizedTell that to the diesel engine and the rocket motors that took man to the moon.
Good for rudy. Did he pull 24 hour emergency service for 15 years In all phases of heat ?Smoke- to send forth steam or vapor, dust or the like.
Great little device that can be found on youtube that burns pellets, collects the smoke and then used in a small engine
Fuel oil has a lower Explosive limit of .7 and a upper of 5(EngineeringToolBox) Rudy originally got the Diesel engine to run on peanut oil
I had a wood stove that would "woof" if you choked off the air too much, when it got a extra little bit of air the gasses ignited and it "woofed". Even almost a swoosh sound as the smoke came out any crack it could. But it never was close to an explosion. The stove was fine if you cracked the air a little more and the damper cracked a bit open. It only did this when you really choked it up.I have seen the blast with a wood stove, it is called "woofing", but never seen it blow the glass out. That glass is tough stuff.
Im talking about fuel oil as It stands. At no time did I say pressurized or vaporized. I simply used fuel oil as a refrence as in if there was a puddle of fuel oil in a system . Ive lit off stuff you have no idea about and it never exploded. Excuse myrefrence maybe I should have elaborated about its temperature pressure and physical state. My bad sorryFuel Oil will explode. In a diesel engine, at around 22,000 psi.... Thats how they run, and run away. Im still on the call sheet, albeit Centrificals these days. Spent near a decade creating fire in 100,000 btu up to 3500 HP boilers, 180 degree water up to 450 psi steam. Ive watched an expired person dissapear in a Incinerator as I tuned the flame. Ive laid my hand on the side of a Forge, it still has no feeling. Hell, I carry 3 welding Certifications- Im comfortable with heat/flame....
After all that, I know first hand- Anything is possible.
My Harman P61a smokes up pretty good before ignition but ignition is very calm. It just lights up and then smoke clears both in the stove and out the vent. Depending on the pellets, some really smoke it up in the fire box and a good trail comes out the vent too. Other pellets light off pretty easy with less smoke involved. But ya, I'm thinking more than just smoke there were gasses of some sort building as well in this case of the OP, apparently. I say apparently because we really don't know what happened.I have only had a pellet stove for 2 weeks so no expert here but shouldn't the combustion blower exhaust any smoke or explosive gases out the stove pipe to the outside. I see people on here say occasionally their forebox will fill up with smoke before ignition but mine will blow all smoke out stove pipe (outside ) then ignites and of couse smoke clears up once fire gets going. I dont see how any gases could accumulate in the stove.
I for one feel I need a blast shield...I will not use the item I need a blast shield forSome additional piece of mind.
