So, I've made a few comments lately on how great my Dolmar ps6100 has worked flawlessly for the last 5 years or so.
Today something seems to be happening with the clutch is my best guess.
I was doing a few things that I typically don't do with my saw today when I think the problem has appeared. It was a bit warmer outside temp than I typically use my saw AND I was noodling some pieces of white oak.
The saw was working perfectly fine for darn near a tank of fuel. While noodling, all of a sudden the saw pretty much locked up and stalled. (Unusual behaviour) I thought I had heard the rpms start to ramp up slightly, which is typically the sign I'm running out of fuel, so I decided that maybe it was simply out of gas and locked up with a hard stall due to noodling.
I went and filled it with gas and it was not completely empty.
Upon re starting after the refuel, the chain was spinning at idle (which was not usual) It seemed to be normal idle rpm. I then engaged the chain break and it stalled out again. I did 2 or 3 retarts and the same behavior continued. Starts easily, but chain spinning when at low idle, engage chain bake, hard stop and stall.
I removed the cover to look at the outboard clutch and I'm not familiar enough to know if I see anything wrong. I definetly did not come across any broken parts that I know of.
I will attach a picture and can any of you folks tell me what my next steps should be? As to what could be going on with my saw.
Thanks for the help
Thanks for the help
