http://www.chimneylinerdepot.com/store/product/6in8in-Factory-Built-Liner-Adaptor/60.html
this is the part you need
Hmmm. That is gonna block off the cooling channels in that prefab chimney.
Pretty much a better explanation of what I was trying to say.It would be very nice to see a picture of the cap. I often am able to cut the top portion of the cap off and leave the base with the air cooling potion intact. Let the liner run up past that base, then use a clamp style storm collar and cap. It works very well.
no actually it doesn't, it allows the air to come thru
i've installed a bunch of them![]()
Dura vent makes a liner kit that's specifically for this application, it wasn't as easy as the way I mentioned above. There was no benefit to using their top kit except its listed, for what that's worth.
Another question I have is how big is that prefab fireplace? I have out several 1750's in prefabs and most often its tight! Even though it will technically fit, you still need both flues to line up and have room to get your hands in there to make the connection. We often end up needing to use an adjustable offset box because there is no room for elbows.
It has a hd screen under neath, which allows for a gap to let the air flow
