Hi all - thanks for the input this far.
I have ordered our stove - a VC resolute acclaim and the dealer is coming to our home this week to have a look prior to the install which should be in a couple of weeks.
The stove will have rear and bottom heat shields installed and will likely be a corner install.
My questions @ this point are:
1) Would ripping out the drywall behind the stove and replacing it with durock and slate tile reduce clearance?
2) I am planning to build the hearth directly over the floor (floating wood floor) any reason why this should not be done? Do I need to remove the floor and go down to subfloor?
When speaking with the dealer - he said that the hearth only need protect the floor from embers and sparks - not t worry about how thick it is... When I mentioned I was reading up on R value he laughed and said it isn't necessary. Comments?
Thanks,
Nick
Thanks,
Nick
