d.n.f. said:Hate to steal the thread here but I have a heat pump question.
I know that below -12 to -15C they don't work anymore and the electric furnace part kicks in. But can you over ride this and just heat with your wood stove instead? My neighbour has a heat pump but no wood stove and is telling me you can't do this.
This concerns me as we get maybe two to three weeks of -12C to -18C weather where I am at.
Also, is the 'central air' part of the heat pump in summer as efficient as central air?
Weeelll, since you asked...
It's not that they don't work at that temperature, they just don't provide enough heat, thus the reason for the electric backup. At very low temperatures, you may want to set it on emergency heat and give the heat pump a rest. It will cost you a little more in electricity, but you will get warm. If you bump the thermostat back when the stove is going, it will start the heat pump automatically if the stove goes out. It is possible to set up an outdoor thermostat to accomplish this automatically, but repeatedly starting a compressor when it is this cold isn't the best thing for it. York units used to do this, but most manufacturers will tell you to just let it run.
The cooling cycle is just as energy efficient as a normal A/C. SOme would argue there is a ssmall loss in the reversing valve, but it isn't significant.
Yes, ground source is very expensive to install, but is probably the most efficient way to condition a building in just about all circumstances. However, if you have made the investment in a wood stove, the air-air heat pump is a great compromise in cost/efficiency. They are great in the shoulder seasons when it is a little too much to fire up the stove.
Now back to your regularly scheduled thread on solar panels...
Chris
  Of course, we also just got the statement for our solar panel loan  :gulp:
