- Mar 24, 2012
- 7
Hello. I bought an older Woodstock stove from a friend of mine for the winter. It's been great but tonight I noticed a crack that runs across a the left-hand top section. I looked inside the stove, it seems to be cracked inside the stove as well. I lifted up the top to see how compromised it was, and there is certainly some give between the cast iron frame around the stone and the soapstone plate itself.
I'm wondering if there are any safety concerns I should be worried about. I have this fear that the top will just split in half and fall into the stove while it's running. Is my mind just going to a paranoid place? How can I fix this? Does this mean the stove has zero value in terms of being able to resell it?
I've attached a photo of the most noticeable portion of crack.![Soapstone Crack in Classic Woodstock--Safe? Soapstone Crack in Classic Woodstock--Safe?](https://www.hearth.com/talk/data/attachments/89/89773-2fdba80d99dfa40077d52a9ebe6317ed.jpg)
Any advice would be greatly appreciated. If it would help
