I do get quite a bot of talk about efficiency and GPH with the folks who visit our store. It is on the minds of people, perhaps more than some here anticipate. But, I do tend to agree that the published numbers should not be used for more than comparison purposes. I say the same thing about the BTU numbers as published, or the square foot numbers. These numbers are all over the place and are misleading in the hands of a novice. It takes a lot of study and detective work to sort it all out so that it makes sense. We discourage taking all these numbers too seriously. However, if asked I will fully explain the meaning of the different numbers and, in the process, help the prospect make an informed decision. If they want to buy by the numbers that's okay. But most understand that the real numbers are far more unpredictable and depends mostly on how they use the appliance and how well they adjust to the different variables that effect the overall efficiency of their stove.
As far as pellet stoves being more efficient and less GPH. Maybe. But again, it depends on who's using it and what they know about how to get the most out of the stove. There is still a lot of variability in these appliances. Until these appliances get more sophisticated they will still be largely dependent on the user for the overall efficiency they are capable of. I suspect a device may exist that only produces water vapor after burning a solid fuel. But it is not in the consumer market. (NASA maybe?) Consumer appliances for solid fuel are still only capable of about 75 to 80 percent efficiency. This can be achieved with almost any modern appliance in the right hands, whether wood, pellet, corn, or coal. They can also be turned into disgusting smoke belchers in the wrong hands.
Didn't we see a positive result in Montana where old stoves were changed out for new stoves (EPA certified) and the air quality in the valley improved dramatically? Seems that could be used to back up claims of cleaner GPH stoves being of high value. I think the message to the regulators has to be that the new appliances have a much better chance of burning clean than an old pre-EPA stove in the hands of the normal user.
Sean
Sean
is!
