50º when I woke up this morning and the temp stayed there all day. Burning electrons in the heat pump for the duration. Looks like we'll be cooling down by tomorrow evening, so that's the likely time for the next fire.
Typically I've never heard of a septic system freeze up, I wouldn't think you have much to worry about, that being said, you could be using some sort of system that isn't the typical we see here?I have 10 above right now, the coldest so far this winter and today’s high will be around 14 so I’ll have a few fires today. We have no snow at all so yesterday I got some straw to put over some of my septic system, I get nervous if it gets this late in the winter and there’s no snow yet.... freeze ups are expensive!
My former girlfriend in VT had a frozen septic system. She corralled her horses on top of the field so the snow never built up which acts as insulation. It was an elevated system where the house went by gravity to a tank and then there was pump that pumped up hill to the leach field. The pumps had a discharge check valve on the outlet so the line to the field is always full. I think her distribution box actually froze in the leach field. Me neighbors gravity system froze once during a really cold winter. Its mounded system and my guess was over 20 years the pipes may have settled so that there were low points in the piping that froze.Typically I've never heard of a septic system freeze up, I wouldn't think you have much to worry about, that being said, you could be using some sort of system that isn't the typical we see here?
Oh sure it happens if there’s not any or much snow cover and the frost goes deep. The frost line up here on a road or bare ground is 4 feet Deep. I’ve seen holding tanks freeze up as well as the 4" pipes going to the septic or holding tanks. It happens more in compacted and clayish soil like ours here is. I see your in Ontario Province and I’m sure it gets quite cold up there but possibly you always have a good snow cover before the bitter cold comes or you have more insulated septic systems up there and possibly some wastewater system codes that make that happen?Typically I've never heard of a septic system freeze up, I wouldn't think you have much to worry about, that being said, you could be using some sort of system that isn't the typical we see here?
