Pete & Dennis,
Well I'm having this done this coming Friday!
Thanks for Information Dennis, I'm going with the same company as You two gentleman did......
They will be going through the brick on about 98% of my house and through the drywall in my laundry room as it butts up to a cinder block wall in a well packed garage. lol
The last few weekends I spent installing 2" closed cell foam board on my basement and crawlspace walls.
Plan on having the rim joists done with closed cell spray foam by next summer.
After that my 1950's era home should really be efficient?
Cheers, Hiram
SQ Footage of home? Thickness of walls?
Good Hiram. You won't be sorry. Pete found as we did that this foam insulation really helps out a lot.
I am glad to hear that Hiram post some pics of it would you please ! Make sure you get the ceilings insulated well too that is very important and cold make all the difference.
Pete
Ours was good last year but this year it is fantastic! It took more than 3 days for ours to cure right I think it needed to be warm out to cure all the way. Ours was put in while it was cold out. We also went around and caulked every crack in our old home and we have no wind coming in and you could heat the place with a match this year. Keeping in mind our home is not stone but wood so I cant speak to how stone/brick react and the dry times involved.
Pete
Home is 2120' Sqft Ranch built in 1951HM, how thick is the cavity again??
Man - I really need to get into action and do something like this in my home. Sounds like the way to go.
The foam came through a few plugs and light switch sockets, so the house had some leaks!
Me too! I'll have to get some prices. I know it will be a great improvement, but I just don't know if I can afford it now. because I'm heating with "free" wood, it will take a while to get my money back. It would probably be more cost effective in the short run to install a second stove.
Here is a youtube vid from there Facebook page for anyone wating to see how its done. pretty neat. Thanks Backwoods for hooking me up!!
