Treacherous said:I've heard many suggest on several snowblower forums that the auger design on the SINGLE stage Toro's is superior to other's including the Honda's.
They are probably just blowing snow up your ---
Brrrrr that has got to be cold
daveswoodhauler said:ChrisN - Please tell us how your new blower performed for you in this current storm....we have 14" so I am guessing you might be getting buried too?
Coming to realize that my 160 ft driveway needs a better machine that my 8.5h orse ariens and 24' cut.
Thanks for the info Craig. Not sure if it is slipping...just doesn't seem to throw the snow as good as it used to.Webmaster said:That's what I did...but mine is an 8526
Maybe you gave the serial number?
I think the manual shows how to expose the belt. The belt is what tensions everything...as I remember, therefore adjusting it tighter or replacing it can help if slippage is the problem.
How about the fuel - clean? Do you put drygas or something else in there here and there? Stabil? I leave my gas in over the summer and still have no problems, but lack of full fuel flow can definitely sap power.
daveswoodhauler said:Thanks Ray....I have the same issue with slushy snow.....throws it about 1 foot max ..so I am going to take of the cover after I'm done work and take a peek. Hopefully it just needs to be adjusted and not replaced.
Not to mechanically inclined, so I might take a few pics and perhaps you can show me on the pics what I might need to adjust? (If you would be willing to?) or maybe PM you?
daveswoodhauler said:Yes Ray, have an Ariens 932104, its about 10 years old or so.
Thanks Ray.....I think your directions are great, and will make more sense when I see it in front of me.
I am guessing I should just move the pulley in a little to see if that makes a difference? Or should I move it all the way so it touches the belt? (Like I said, might make more sense when I look at it)
Thanks so much!
raybonz said:daveswoodhauler said:Thanks Ray....I have the same issue with slushy snow.....throws it about 1 foot max ..so I am going to take of the cover after I'm done work and take a peek. Hopefully it just needs to be adjusted and not replaced.
Dave do you have an Ariens snowblower? On mine there is a plastic cover over the belts held on by 2 bolts.. If you remove this cover you should see 2 belts.. The larger heavier belt is the auger blower belt and if you press the lever which engages the auger/blower you will see an idler pulley being moved towards the larger belt engaging it to the engine pulley.. Loosen the idler pulley and move it towards the center of the machine.. On mine I noticed the engine loading when I engaged this pulley after moving it.. This made a massive difference on my machine and should on yours if you had the same problem as I did! Hope this helps..
Ray
Czech said:raybonz said:daveswoodhauler said:Thanks Ray....I have the same issue with slushy snow.....throws it about 1 foot max ..so I am going to take of the cover after I'm done work and take a peek. Hopefully it just needs to be adjusted and not replaced.
Ray
So I just checked my Ariens 824 as said, yep, a good half an inch make up was due. I noticed on Dome killer weekend it was not handling the slushy stuff as well as it used to, I did the traction disk last year so was thinking it should be good to go. In seeing how much space there was, makes me wonder how it was throwing at all? Impeller just slipping? She's tight now, pulley free wheeling when let go, tight when handle squeezed. I haven't used it yet, but feel pretty confident I'll see a big improvement. So.......Thanks for the idea Ray!
mayhem said:Tightened mine up last night too, now I jsut need to get it out and try it I had probably well over an inch of deflection and the idler pulley was at the furthest out adjustment. Moved it all the way in and we'll see how it goes. Best now has about a half inch of playw hen engaged. Probably time for a pair of new belts anyway as they're very, very old. I squirted some belt dressing on them to add a little moisture though.
