I have a smoke problem. I have a Lopi Answer. Recently replace my Jotul.
I begin the fire with a Top Down without problems. No smoke on start up.... I GOT IT WORKED OUT.
I place the two medium pieces as far back as possible. Then crossed a few smaller (shorter) pieces so they fit north to south. Then smaller pieces to start the fire on top an four pieces of newspaper rolled and tide...
Let the door open until it get on fire ---- the Lopi here has enough draft - and I get no smoke coming out. I get the fire going fast..... with little pieces that burn very well.
Then I close the door or leave it just half an inch open until it is well going. Then I close the door and leave the air input fully open.....
MY PROBLEM IS ON RELOAD ----- I get smoke into the house.
I AM FRUSTRATED SEEING SMOKE COMING OUT WHEN I OPEN THE DOOR WHEN I NEED TO RELOAD.
I AM FRUSTRATED WITH SMELLING SMOKE....
IF I NEED TO MOVE A LOG - OR DO ANYTHING THAT IMPLIES OPENING THE DOOR - I GET SMOKE
The fire is roaring hot. The Lopi is full of red hot ambers. BUT I GET SMOKE INSIDE THE HOUSE
My old Jotul did not have this problem.
My flue seems to be installed following the standards. It is just under 4.6 meters tall
It has a half shield on to the corner inside the house
The only way I think that I would not get smoke is to let it die down before I ope n the door - but this does not seem practical or right.
Can someone with the Lopi Answer explain to me how they run this machine?
en a little bit
Today I just refuse to reload. Just tried again. I have the air inlet fully open. Decided to open the door half an inch for a few minutes to give it extra draft/heat and time for me to muster the courage to open the door. There was a log red hot siting right at the back and a very nice bed of red hot ambers......
I opened the door a little bit more... slowly... carefully... and then mustered up the courage to open the door fully to load a new log....
Smoke poured out.... So I gave up, closed the door and decided to never turn the Lopi on again. Again had to open the windows and back door...
Tired of the smoke....
The wood I am burning is very well seasoned.
Is this a draft problem?
During one of my first attempts to begin a fire --- I noticed on two occasions that I had smoke coming out of the air inlet but most supprisingly, smoke coming out from UNDER the Lopi form what I think is the OUTSIDE AIR inlet - which I think should be cealed.
NOW SHOULD I:
1) PUT A LONGER FLUE?????
AND/OR
2) INSULATE THE FIRST METER OF THE FLUE with a perforated FULL FLUE COVER?????
REGARDS.....
NEW LOPI OWNER ---- MISSING MY JOTUL![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
en a little bit
NOW SHOULD I:
AND/OR
REGARDS.....
