Hello everyone! I have read a lot on here and it has been very helpful. Now I have an issue I need your help with!
I built my tiny house this year and installed a Jotul F602, using Duravent DVL inside and Duravent Duratech outside. The stove I purchased used but the stove pipe is all brand new.
My issue is that I am having a decent amount of smoke coming out of the transition through the wall (photo attached). I have read other threads on this issue and I henge checked over things from those threads. The cap is not clogged, I've inspected all the pipes for clogs, my wood is 15-20% according to my moisture meter, I have run the stove with windows cracked to make sure there was enough air for draft, and I have replaced the adapter in that joint to make sure something wasn't wrong there.
I can not seem to track down what my issue is. It is cold, please help!
![Smoke leaking into home. Smoke leaking into home.](https://www.hearth.com/talk/data/attachments/286/286527-c00f6191b26ff561da1cc3f87a46374c.jpg)
![Smoke leaking into home. Smoke leaking into home.](https://www.hearth.com/talk/data/attachments/286/286526-01133340aaff0592a7fa177448abc0cd.jpg)
