![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218619-4d0cdb581ae4ff874b5463bb5513add6.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218620-66f865023968ca5525cbbc30dd93e683.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218621-0879eb7b7d0c99d61d93f65683041795.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218622-c8962fe5d9ae91f806305e4db7336f0c.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218623-512a57daf2b10ff376f0047b9ac255e7.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218624-1beaba835c89c9c18c82d1cadce878b2.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218625-dee2df22776e53693d6ee0c54b700d10.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218626-e892a78adeb4d30fb19aa9ccdbf34101.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218627-9fe94972a15cc9da1ba812d56188e520.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218628-1bc0130fdc39e3e6b2339f974ef08edd.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218629-9001f941636f35d8c8d10dff36b3922f.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218630-9ec526f765f6b491a228dbf0b35777dc.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218631-092866c8bfd526dfa59f881c5866c752.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218632-0b104c73d77c3af173b97fcf597c40ae.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218633-a3b7a6cd1a5df6cfa2de1bfcd3addc08.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218634-3b235e51a1e1d86941dfa79bd88294af.jpg)
![Smoke in house, Country Elite E260 Insert Smoke in house, Country Elite E260 Insert](https://www.hearth.com/talk/data/attachments/218/218635-9be7192402fb4d1a8da02e05d79008c0.jpg)
Hello, I have a Lennox Country Elite E260 insert that came with the house when I bought it. The insert is used and was installed without a liner, the insert smoked the house up, so about six years ago I called the only fire place shop in town and had them install a liner, unfortunately I am still having a problem with smoke filling the house and also a chemical smell like burning paint. So I put off using the insert all those years and now finally have some time to troubleshoot the problem.
I have been in construction all my life and have installed a fire place and two wood burning stoves and I am very mechanically inclined and have read many threads trying to troubleshoot this problem, but as you know every problem can have many different solutions specific to its particular situation and I hope you guys can help me figure this out.
So here are the particulars:
House is located in central California in a valley up against the foothills, elevation 390'
The house is not tightly sealed very drafty.
Lennox Country Elite E260 insert, guessing that this is the model by internet pictures and a PDF manual I downloaded, I was told a company called Ironstrike.us.com now manufactures this stove under the name Legacy, correct me if thats wrong.
Flue 8" round, protruding up 1/2" from the top, rear portion of the flue is 1/2" from back edge of insert. Square flue connector is 10" wide 8" deep slanted towards the back and will not sit flat on top of the stove due to the 8" round flue sticks up a 1/2" and hits the back slanted part of the connector. Top of flue to top of vent cap is 15 feet, top of vent cap is even with pitch of roof.
6" flex pipe is connected to 6" double wall stainless pipe, not sure if it's insulated. Brick chimney located outside of the houses interior, outside measures 24" x 24" , top of brick chimney measures 16" x 12" , I cannot measure the inside due to the flashing is caulked.
I will be doing this job myself because as the old saying goes, if you want something done right do it yourself. Of course I am not a expert on fireplace installation and that's why I'm here for you to guide me to correct any problems you guys see.
- First lets start with the pipe, is it long enough?
- Is double wall pipe insulated between the layers of the pipe?
- If not, Should the pipe of been insulated on the outside?
- There is a air vent in the brick chimney at the base leading into the insert location, should that be blocked off?
- Should there be a sheet metal partition around the flex pipe separating the insert from the brick chimney where they removed the brick and damper?
- The installer put insulation between the insert surround panels and the brick, is that correct? This is what the installation manual says: Note: When installing your stove with a positive connection, be sure to leave the insulation off the surround panels (flanges) and leave a 1/4” (6mm) airspace insulation off the surround panels and the facing of your fireplace.
- Is that the correct type and size flue connector?
- What is the correct way to attach the flue connector to the flue, do you use that white ceramic wool between the two, or just flush with no insulation?
- The installer used the white ceramic wool because the connector did not sit flat near the back and he needed to fill the air gap it left. I also discovered that the ceramic wool was protruding into the flue 1-1/2" on both sides reducing the flue, pics provided. He used nine self tapping screws, three on both sides and three on the front, none on the back.
- I can not identify the wood from a tree in my front yard and it was not split but two years old stored out of the rain. The fire starts fine and burns great but you notice the house filling up slowly with smoke, not so obvious that you can see where it is coming from, and when I smell the air coming from the fan it has a chemical smell like curing paint, maybe from the species of wood or I also use duraflame quick start blocks 1" x 1" square to start the fire, maybe that's the chemical smell, should I not use those.
- The air damper seems to work fine, starts fine with the door closed and burns good and dampers down fine, when I need to load wood I open the damper all the way open, then crack the door to let things settle down and slowly open the door but I always get a small puff of smoke entering the house, why is that?
- Is there anyway to test if the insert is leaking into the recirculating fan area, as you can see in the pics there is some discoloration and also what appears to be creosote or maybe that's just slag left over from the flue being welded to the top plate.
- I tested the door seal with a dollar bill and there is a tight seal.
- There are two air tubes I notice, one in the back and the front, do those need to be replaced or cleaned?
- I noticed lots of dead spiders and bugs and dust on top of the insert and also a sticker on the flue connector the was melting with glue burning, maybe another source of that chemical smell.
- The top surround panel also has a black rubber substance on the back, why is that on there?
- The installer replaced the ceramic wool insulation blanket that sits over the top bricks and under the flue, but instead of using one full sheet he cut three pieces and installed them through the flue. Is that correct?
- The paint is coming off the insert and the gold is flaking off the door, is that from the previous owners getting it to hot?
Ok guys, work your magic
