During my last test fire, I found something concerning. There are two areas toward the back of my stove that I thought I saw smoke coming out of. Well that cant be right!? I took a flashlight and sure enough, there is smoke coming out of the back. HOPEFULLY it is just manufacturer oils / paint fumes coming out of there, but honestly after my last couple of burns we no longer smell those fumes that we did when we were breaking in the stove. I checked again when I shut down the primary combustion damper to allow for secondary combustion burn, and the smoke was no longer coming out from there.
So I'm pretty sure it is smoke and not oils/paint smoke.
Any ideas as to what this could be and how to resolve?
At this point I was at about 400 degrees and added a couple of pieces of wood trying to get temps up a bit more. I was about 2 hours into burning at this point. I had it up to around 500-550 for a bit then let it die down as I did work. The wood im using is 20% moisture content per my general calibrated moisture meter, testing after splitting a piece in half. The primary combustion damper was open as I had just added wood not too long ago and I was waiting until it hit 450 to close it for secondary burn.
I honestly barely saw it until I used a flashlight. My eyes were starting to burn but I didnt see any smoke coming from anywhere until the back of the stove caught my eye and the flashlight confirmed.
Thoughts?
Also are Midwest stove thermometers considered decent? I bought one and compared temps to my laser thermometer. My laser thermometer kept showing that it was 50-100 degrees difference (lower) than what was being read on the midwest thermometer. It wasnt until the stove top thermometer hit about 500 degrees that they both agreed within 25 degrees. I put a pot of water on the stove, waited a bit then tested the pot of water at 161 degrees with a very accurate insta read digital meat thermometer (gotta have for good brisket), and my laser thermometer - they both read EXACTLY 161 degrees, so my belief is that the Midwest thermometer is off until it hits around 475-500 then it seems accurate after that. But that doesnt serve me well to be that far off below 500 degrees.
![Smoke exiting the rear of my Vermont Castings Dauntless. Smoke exiting the rear of my Vermont Castings Dauntless.](https://www.hearth.com/talk/data/attachments/298/298972-be0ad8b615676f98fd7ab4510be5095d.jpg)
Thoughts?
