Did the cleaning stop the smoking issue?I can't see if there buildup in liner. The last chimney sweeper I had here used a medusa head cleaner and really seemed to do a good thorough job. Even if I keep the bypass open all the way all the time with the fire burning, there will still be smoke that comes into the house when I open the door.
I also tried to keep off the fan for a few hours to see if prevents smoke from coming in and it doesn't stop.
Your wood is way to wet. We know that. So it isn't going to burn right. But it shouldn't be smoking with the bypass open and air opened up ahead of timeThe cleaning did not stop the smoke issue. Cracking two windows (13 feet away from fireplace) for 5 minutes did not help at all.
I should mention that when the bypass is closed, there is very little flames if at all mostly the wood starts smoldering after a while. I remember last year after the fire was roaring if the bypass was closed halfway the fire would still roar but not as much.
This morning, I swept out the whole fireplace, kept an inch of ash on bottom, using a few pieces of dry wood from Home Depot. Still smoked. I am at a loss.Your wood is way to wet. We know that. So it isn't going to burn right. But it shouldn't be smoking with the bypass open and air opened up ahead of time
What type of wood was it? If it was the firewood packs they usually aren't very dry either. Try some 2xs or compressed wood bricks. What temp are you closing the bypass at?This morning, I swept out the whole fireplace, kept an inch of ash on bottom, using a few pieces of dry wood from Home Depot. Still smoked. I am at a loss.
Do you have the digital cat monitor?Honestly, I don't know what wood it was. I tried Durflame and then Biobricks. Both Smoked.
I don't know what temp I am closing the bypass at. That wasn't an issue last year. After the fire had decent flames, I would close it most of the way. What temperature ideally should I close the bypass at.
The highest temp I am getting is 650 - but most of the time it is 450-500
Then you should shut the bypass around 500. What does the temp do when you do that?Yes I do.
If the cat temp doesn't go up when you shut the bypass your cat is completely shotok cat monitor read 500, I shut the bypass closed. the temp stayed at 500, not many flames, just smoldering wood after several minutes. I then waited for five minutes, opened the bypass, waited 2 minutes, opened the door and smoke still came in.
Let the temp monitor get to 550F or 600F, and then close the bypass, don't put it halfway. Temps should rise unless your wood is "quite wet."The cat does have a sizable hole (size of a quarter) and a few other places its starting to crumble, waiting for the replacement to come. Would that cause so much smoke to come in?
Yesterday, I had the bypass half open, temp was 400. I then shut the bypass closed and the temp went to 500.
I should not, when I went up today the roof to inspect the chimney screen, there was smoke coming up and outside.
Why are you closing the bypass halfway?Let the temp monitor get to 550F or 600F, and then close the bypass, don't put it halfway. Temps should rise unless your wood is "quite wet."
I think whats happening here is overly opening the door, I'll agree that the cat is prob shot due to poorly seasoned wood being used from seasons before, and thermal shock from opening the door. You cant get water to burn in these stoves, best to replace the cat, buy compressed wood bricks or not burn at all this season.
Get some decent wood first or you will just destroy the new one with thermal shockGreat thank you. I will see what happens when the the cat is replaced
That is your wood for sure. In a properly working cat stove just smouldering is fine. But your cat isn't lighting offBecause if I close it completely, the fire almost dies out and just starts smoldering, no flame.
