I see the advice of running small loads in a big stove come up often enough on this forum, either in milder weather, or because the stove is just too big for the house. But I wonder how many doing this are failing to achieve a clean burn, due to insufficient heat and fuel to activate the secondary burn system.It's plenty big enough for heating 850 sq ft. You may find yourself running partial, 4 split loads in milder weather. Just be sure that the wood is fully seasoned.
Running more than 100 cords of wood through a series of catalytic stoves, I've seen first-hand how difficult it can be to achieve cat light-off with a small load of wood, due to a combination of less heat coming off the load and less fuel being generated to support secondary burn. A non-cat should be even more problematic, in this regard, requiring roughly twice the temperature rise of a cat stove to achieve secondary burn.
If run WOT, I suppose one could still burn clean enough, either by more complete combustion in the initial burn phase, or by eventually getting the secondaries to sufficient temperature for reburn. But how many are running WOT for an entire burn, on these smaller loads?
Is it likely that small loads in a big stove results in not only much lower efficiency, but much dirtier burns?
