I have the new econoburn 150 up and running and have
been testing it trying to learn how it all works.
So far, so good, ol man winter gave us a parting shot
of arctic temps so that was good to have for loads.
My basement is aprox 2500 sqft and has 9 300 ft pex loops
in the slab over 2" blueboard base. It's fed via a grundfos 15-58.
Yesterday I dialed the lp boiler down to 90 and ran up the econburn
to 175 then set up the thermostat started moving water.. It took less than
ten minutes to stall the wood boiler!! By stall I mean the boiler temp dropped
from 175 down to 145 and shut off the main circ.
Granted I had maybe a quarter wood load but it was gassifing good.
I was kinda shocked at how much load it takes to bring up the temps..
I'm guessing it will take fine spits loaded to the max a couple of times
over to move this.. I ran three smaller loads into the slab last night
and barely got warm water out of the return, finally dialing down
the mixing valve down to 100 degrees, the basement felt very
hot even tho the thermometer said only 73 degrees. It looks like
good storage as the whole house was warm this morning even thou
the wood boiler went out sometime during the night..
Any insights on this would be very appreciated..Is it better to
heat a storage tank or the slab? Will the storage tank pull down
the boiler as much as the slab does? Is there a good way to put
in a small flow all the time? tnks
