BobcatBranch
Outside Air Kit. It allows the stove to get air directly from outside in poor draft situations, and mobile home applications.What is an OAK?
Is it necessary? I like the look of a single pipe going out the wall, but imagining a second line out the wall seems cluttered.Outside Air Kit. It allows the stove to get air directly from outside in poor draft situations, and mobile home applications.
I am the office occupantStoveliker has good points. Since you're starting in the basement, you have the opportunity to install a stack tall enough to get some good draft.
The office occupant is going to love the heat!
No. It's going to be finished. The house HVAC was sized for the whole house and is ducted on both floors. The wood stove is not necessary, I just wanted to add one for an extra backup heat source during power outages or for ambiance downstairs. I will work out of the office daily and if we have guests they will reside downstairs, so it'd be nice to have some nice warmth like that down there. I could add a propane fireplace but I've never had a wood stove and now live in a rural area on 5+ acres so I've got access to wood from both my own property and the in-laws hunting land of 500+ acres.If you are willing to leave the ceiling open, (no sheetrock), you should get some floor warming from the stove. Mostly above the stove room area.
The necessity may become obvious after installation. If you're careful to match your stove to your proposed flue, it may not be necessary.Is it necessary? I like the look of a single pipe going out the wall, but imagining a second line out the wall seems cluttered.
The quality of wood heat is hard to beat. The Escape 1200 requires a 12ft flue minimum.No. It's going to be finished. The house HVAC was sized for the whole house and is ducted on both floors. The wood stove is not necessary, I just wanted to add one for an extra backup heat source during power outages or for ambiance downstairs. I will work out of the office daily and if we have guests they will reside downstairs, so it'd be nice to have some nice warmth like that down there. I could add a propane fireplace but I've never had a wood stove and now live in a rural area on 5+ acres so I've got access to wood from both my own property and the in-laws hunting land of 500+ acres.
What stove is in there currently? If it's a modern stove then the answer might be to run it with smaller loads of fuel when less heat is needed.What did you decide on? We're looking to replace a wood stove in our basement (also a ranch, about 1500 sq ft per floor). Our basement is mostly open and unfinished. We use it as a gym. (Thankfully, I prefer to work out in the morning before the basement heats up too much.) We keep hearing go big, but the stove we're replacing was only 40k BTU, and it got us too hot sometimes upstairs. So I'd love to know what you went with and how you like it.
We bought the house with a Vermont Castings Dutchwest 2478. We used it for a year, but it's at its end of life. We're debating between a Kuma Aspen or Kuma Ashwood--leaning toward the Ashwood, but just don't want to get too hot, waste wood, or run so low we run the risk of creosote. Even with the Dutchwest, we (...okay, I) kept the bedroom door closed and sometimes opened the window for sleeping. I do wonder if a newer stove would work/heat differently--I've heard that--and/or maybe part of the Dutchwest's heat came from it not running properly from being worn out.What stove is in there currently? If it's a modern stove then the answer might be to run it with smaller loads of fuel when less heat is needed.
That’s actually great to hear. We struggled with it a ton the year we used it. I’ve seen in threads here that it isn’t an easy stove anyway, but maybe our struggles were also due to the internals breaking down.That's possible. A stove can be hard to regulate when the internal are breaking down.
