Single pipe for exhaust?
Brandonjr36
26
Joplin missouri
I just installed a new to me king wood pellet stove, my old Breckwell went out and my old stove had a straight pipe leading outside. So I built my stove up with blocks and now have my pipe going straight out. I’m getting a smoke smell in the house. I read online that you’re not suppose to have just a straight pipe but I did on my Breckwell for over 25 years. My exhaust fan does have a lot of soot on it. I ordered a new one online should be here by the end of the day. I’m gonna replace it and see but just want to see what everyone thinks about me having a single pipe coming out of the stove. It’s about 18 or so inches from the adapter
  • [Hearth.com] Single pipe for exhaust?
Oh ok, clean out T would help…straight leaves opportunity for ash to build up
Can I run it this way for a short period of time? I don’t mind cleaning it often. But I really need this stove to work this week as it’s going to get down to 6 degrees in my area. Hoping I can get the smoke smell to stop inside
Not sure what the code is in your area but as long as exhaust can flow and it’s kept clean it should be ok for a short time necessity wise
Are the pipes sealed with high-temperature sealant?
This adapter piece is. But not the pipe going to it I never had it sealed on the old stove either. If I seal it then I won’t be able to take it apart to clean it but this adapter piece has a ton of sealant on it
per the owners manual pg.6
MAXIMUM VENTING DISTANCE: Installation MUST include at least 3-feet of vertical pipe outside the home. This will create some natural draft to reduce the possibility of smoke or odor during appliance shutdown and keep exhaust from causing a nuisance or hazard by exposing people or shrubs to high temperatures. The maximum recommend vertical venting height is 12-feet for 3-inch type “PL” vent. Total length of horizontal vent must not exceed 4-feet. This could cause backpressure. Use no more than 180 degrees of elbows (two 90-degree elbows, or two 45-degree and one 90-degreeelbow, etc.) to maintain adequate draft.
So should I run my exhaust straight outside then put and elbow on and go up a couple feet?
As per your owner's manual
The pipe must be sealed so you do not get smoke in your home
You can use removable silicon high-temperature tape to seal the pipe joints
on your pipes inside your home.
Reactions: Ssyko and Washed-Up
I would put a clean out T outside then go up the manufacture recommended distance
Reactions: bggzm85
