perplexed said:BrotherBart said:When I am at home I burn two at a time. Seems to use more wood but I can manage the temperature better.
A question along these lines comes up as I read these threads...When throwing just 1 or 2 logs in are you burning with primary air all the way open or can you shut it down? Non cat stoves/inserts.
With hot coals to lay them on two E/W splits with a small gap between them allow me to almost immediately close the primary down to a 1/4 and most of the burn takes off on top of the wood. The coals need to be just large enough to allow air to pass under the front split.
