Working on chimney upgrades to hook up a 2015 magnolia wood stove, but while I'm ordering chimney things, I want to get the stovepipe as well. I think I'd be okay with clearances since the whole area is masonry or stone and the closest combustible material is the drywall on the ceiling about 16 inches away from the edge of the thimble where a 45 will connect and point down towards the stove.
Should I use double wall stove pipe anyway? Will that help with draft and creosote formation considering I have to deal with a 90 degree elbow/tee into the masonry thimble?
I'm looking at the Rockford stove pipe, if that makes a difference, not the cheaper pipe that you have to snap the seam together. *the previous owner had single wall stovepipe going to an older pre-EPA stove apparently without issues.
![Single or double wall stove pipe? Single or double wall stove pipe?](https://www.hearth.com/talk/data/attachments/307/307318-336ec274f11ab04508cb45ba14312751.jpg)
