Silicone fumes! When will they go away?
Peanutavalon
2
Cape May
Hello. I am new to the forum. I had to replace the gasket on my glass fireplace front. It is a Vermont castings DV fireplace. I watched a few videos that recommended using red silicone to adhere the glass to the metal frame. I used imperial brand red silicone 600° the stuff worked great.. Tight bond, but when I turned on the fireplace the next day I got terrible fumes. Is this normal? How long will it take for them to go away? Anyone ever experienced this? Thanks.
I also forgot to add that I used some high temperature spray paint on a small rusted section on the inside of the fireplace. Could that be what I’m smelling as well?
  • [Hearth.com] Silicone fumes! When will they go away?
There is a "Burn in" process for new gas appliances where the unit is run on high for a number of hours(sometimes as many as 8).
This burns off the oils used during manufacturing and cures the paint.
You may need to do something similar.
Reactions: DAKSY
Thank you for the reply. I did a little searching on Google. I got AI responses, but they say similar things. There is a burn in Period when new sealants and paints are applied. I just wanted to make sure the sealant I used was not a mistake.
Reactions: Lennox65
