I am glade I don't live where you do. And I don't have the
cry babies you do.
I make noise, the two neighbors that are kinda close make noise, and no one cries about it
I recently had trouble with the authority's about a inoperative unlicensed vehicle ,that had been there for years,with no complaints anyway, long story short, ended up having to go to court,I repaired it ,put plates on it, and it was dismissed.
Here is the Ordnance ,I just wanted to show the part in bold ,but read it all if U like
The red part, I never did ask the cop about washing it before I put plates on it
Oh ya , check the blue part
Some of this stuff is never enforced, some of this stuff is ridicules
A vehicle looks the same with or without plates
EXTERIOR PROPERTY AREAS
302.1 SANITATION - All exterior property and premises shall be maintained in a clean, safe
and sanitary condition. The occupant shall keep that part of the exterior property which such
occupant occupies or controls in a clean and sanitary condition.
302-8 MOTOR VEHICLES - Except as provided for in other regulations, no inoperative or
unlicensed motor vehicle shall be parked, kept or stored on any premises, and no vehicle shall
at any time be in a state of major disassembly, disrepair, or in the process of being stripped or
dismantled. Painting of vehicles is prohibited unless conducted inside an approved spray
booth
Exception: A vehicle of any type is permitted to undergo major overhaul, including
body work, provided that such work is performed inside a structure or similarly enclosed
area designed and approved for such purposes.
ZONING ORDINANCE
4.50 PARKING, STORAGE AND REPAIR OF VEHICLES - The following standards shall
apply to any storage or repair of vehicles within any zoning district:
1. All vehicles parking or being worked on in a front yard area shall be on an approved
driveway surface, licensed and operable. Approved driveway surfaces include asphalt or
concrete. Stone base or gravel is acceptable as a temporary surface for up to one (1) year.
2. Routine maintenance procedures (such as washing, changing oil, fluids, belts or spark
plugs) on a residential lot shall only be permitted on a licensed vehicle that is owned or leased
by the owner or tenant of the principal dwelling. Such maintenance procedures shall be
permitted for a maximum of four (4) consecutive hours and a maximum of five (5) days during
any single month. Procedures which require the vehicle to be immobile or inoperable in
excess of five (5) consecutive days shall be carried out within an enclosed buiiding or off the
premises.
3. inoperable vehicles and vehicle parts shall be stored inside an enclosed building.
Section 4.50.1: All vehicles parking or being worked on in a front yard area shall be on an
approved driveway surface, licensed and operable. Approved driveway surfaces include
asphalt or concrete. Stone base or gravel is acceptable as a temporary surface for up to one
(1) year.
Section 4'50.2: Routine maintenance procedures (such as washing, changing oil, fluids, belts
or spark plugs) on a residential lot shall only be permitted on a licensed vehicle that is owned
or leased by the owner or tenant of the principal dwelling. Such maintenance procedures shall
be permitted for a maximum of four (4) consecutive hours and a maximum of five (5) days
during any single month. Procedures which require the vehicle to be immobile or inoperable in
excess of five (5) consecutive days shall be carried out within an enclosed building or off the
premises.
Section 4.50.3: inoperable vehicles and vehicle parts shall be stored inside an enclosed
building.
Section 4.50.4:
parking of tow trucks is prohibited in any zoning district except on a lot where
the principal use involves approved automotive service or repair.
Section 4.S0.S:
parking of commercial vehicles over one (1) ton within a public street right-of-
way is prohibited.
Section 4.50.6: Parking of commercial vehicles over one (1) ton anywhere in a residential
district is prohibited; except parking and storage of larger vehicles for farming or lumbering.
operations is permitted in residential districts if the Building Department determines the vehicle
is used exclusively for uses or activities permitted in the district.
4.58 RECREATIONAL VEHIGLE PARKING AND STORAGE
The outdoor parking of Class A, Class C, and non-motorized recreational vehicles,
snowmobiles and boats for periods exceeding forty-eight (48) hours is prohibited in the front
yard except within approved recreational vehicle storage yards. When Class A, Class C, and
hon-motorized recreational vehicles are stored, the vehicles must be stored only within the
confines the rear yard or side yard when behind the front building line of the principal
building; and shall further comply with the side and rear yard setback applicable to accessory
buildings, set forth in Section 4.2. ALL recreation vehicles parked or stored shall not be
connected to sanitary facilities and shall not be occupied'
Definitions of recreational vehicles (RV): Various types of "Recreational Vehicles"
include:
A. Travel Trailer: A portable vehicle on a chassis, which is designed to be used as a
temporary dwelling during travel, recreational, and vacation uses, and which may be
identified as a "travel trailer" or a "fifth wheel" by the manufacturer. Travel trailers
generally include self-contained sanitary, water, and electrical facilities.
On an industry-wide bases, this type of recreational vehicle is classified as a non motorized recreational
vehicle.
B. Pickup camper: A structure designed to be mounted on a pickup or truck chassis with
sufficient equipment to render it suitable for use as a temporary dwelling during the
process of travel, recreational, and vacation uses. On an industry-wide basis, this type
of recreational vehicle is classified as a non-motorized recreational vehicle.
C. Motor home: A recreational vehicle intended for temporary human habitation,
sleeping, and/or eating, mounted upon a chassis with wheels and capable of being
moved from place to place under its own power. Motor homes generally contain
sanitary, water, and electrical facilities. On an industry-wide basis, this type of
recreational vehicle is classified as either a Class A or Class B recreational vehicle. A
Class A or bus type recreational vehicle has the luggage compartment below the living
quarter. A Class B recreational vehicle is a van without a bed over the cab. A Class C
recreational vehicle is a van with the bed over the cab and is much larger than a
passenger van due to the bed over the cab.
D. Van/camper: A recreational vehicle intended for temporary human habitation,
sleeping and/or eating. This class of recreational vehicles includes conversion vans and
camper vans which may contain refrigerator as well as water and electrical facilities.
This class closely resembles passenger vans, but some models may be taller to allow
for extra head room. On an industry-wide basis, this type of recreational vehicle is
classified as a Class B recreational vehicle.
E. Folding tent trailer: A folding structure mounted on wheels and designed for travel
and vacation use.
F. Boats and boat trailers: Boats, floats, rafts, canoes, plus the normal equipment to
transport them on the highway.
G. Other recreational equipment: Snowmobiles, jet skis, all terrain or special terrain
vehicles, utility trailers, plus the normal equipment used to transport them on the
highway.
