I have only basic carpentry skills and I'm a big believer in keeping my wood/heating expenses to a minimum. I've always kept my stacks out on the edge of our woods. They get plenty of hot wind during our summers, plus afternoon sun, but the stacks are under trees and get really messy with leaves and other debris, which hold moisture and causes some minor rot. So...I'd like to build a shed that I can move seasoned wood into, leaving green wood out in the open for a couple of years.
I'd like to use materials that I have around the property. We just had our large home reroofed after a Springtime hail storm. The old, and new, roofs are metal.
I have a great deal of the old metal panels that I kept. The panels are all 20 feet long. I will, therefore, make the shed about 20 feet wide so I don't have to cut the panels to length. This will mean that the ribs of the metal panels will lie side to side, rather than front to back, so I will need to have a slight tilt to left or right for a bit of drainage. No big deal. I have enough of these 20 ft panels to make the shed 12x15 feet deep. That's much larger than what I need for firewood so it will give me storage space to get some of my tractor implements under cover.
I have several 12 foot 2x6 planks (treated). I have a dozen or so landscaping timbers that I could use for uprights but I'm thinking treated 4x4s might be better (and would have to be purcha$ed). I've got a bunch of about 4 inch diameter cedar poles that could be used for the supports for the roof. I also have around 80 or so 18 inch and 30 inch 2x4 pieces that were used for packaging the new roofing panels. I can use these 2x4 pieces to frame the roof, and maybe use them to frame the sides.
I'm a big fan of deck blocks, having built several decks using them. So, I'll probably go that route rather than pouring cement for the support beams, and will use pallets for the floor.
The space I have in mind is on the edge of the tree line behind our house. There is a large dead oak there that I want to take down anyway. To do that, I'll have to clear out a large area of scrub oak so that I can safely access the tree. That's going to leave a large, open space once I'm done. Why not put the shed there? Easy access. Will get lots of sun and strong westerly winds. And it will meet the Bride's rule of keeping the wood out of view from the house. I'll probably need to hang a tarp in the front, at least during burn season, since it will be facing west and could have a lot of rain blown in.
Shouldn't cost me much of anything, 'cept maybe for some 4x4 posts. It won't be as fancy as some in this thread but it should do the job with little expense.
What do you think?
