Should I upgrade?
Gearhead660
1,047
Southern WI
Im on the fence on whether to upgrade or stick with the ol' VC(mid 80's Vigilant). Was main heat until i got furnace, now not used as much(wood hog). Still use when temps get frigid. Was thinking maybe a cat stove? Would rather not replace chimney($) so would have to be rear exit. Thoughts? Opinions? Options? Pic of current setup posted.
  • Should I upgrade?
Limited options with rear vent. Woodstock keystone comes to mind. Great heater apparently.
Maybe some new gaskets would make it burn more efficient. Probably leaks air terribly.
What is the distance from top of hearth surface to center of thimble? This will really focus your options if you are not interested in altering the current setup.
Are you venting into a insulated stainless steel lined chimney now? Or is it clay lined?
I would look at the rear flue requirement as a happy excuse to limit your choices to Woodstock stoves. Their mid size PH would look great there.
Reactions: Ludlow
Just saw a used Keystone for sale the other day, but missed out... that's what got me thinking about upgrading. Nice looking unit.
Reactions: Diabel and moresnow
There have been some real pleased WS Absolute Steel guys lately. Not sure about the fit. Worth a snoop!
Reactions: Gearhead660
I believe its 25-28", will have to verify. If I have to build up the floor because a new one is lower, I am up for that. brick chimney with steel liner. In middle of house, not external, roughly 35 feet tall(old 2 story farm house).
Never heard of them before. Nice stoves. Affordable too. Sweet how its a tube type and cat stove all in one.
forgot to add...8" flue. May have to update chimney if that limits options. ;sick
I upgraded from a mid 80's VC Resolute to WS Fireview and then the Progress Hybrid.
Advantages: Much less wood usage, much much longer burn times
Disadvantage: just the cost
I know it needs a new griddle gasket. Others look decent.
The Woodstock line does not use tubes, they use a perforated stainless steel plate for the firebox roof. This is a good thing since the typical ceramic baffles are very damage prone. Also, the tubes aren't there hanging down into the firebox. You wouldn't think they would get in the way being only like 1/2" thick usually but I bonk them a lot while loading.
The keystone looks good but is a tiny stove that excels in heating a small home. Your chimney length and location make me think that you would benefit from more horsepower of the larger line.
I didn't mean actual tubes, just the type with secondary air. The Ideal Steel Hybrid has peaked my interest.
Got it. The IS is slightly bigger than my medium sized princess at 3.2 CF though Woodstock has been overly optimistic in the past with their firebox measurements so you're getting a pretty large medium stove with the IS. The biggest that woodstock makes. The IS is the stove I would choose from woodstock if I had to replace my princess cat stove since it is welded steel, very efficient, a straight in front loader, easy cat access, and user reports show a wide range of available outputs. It can burn at really low settings for a long burntime or high settings for a shorter burn time. The PH for comparison, though smaller, can not be turned down as low so burn times are much shorter.
The Woodstock stoves don't look normal. Neither does my BK. Must be something about these high performance stoves that they have to be weird looking! So be sure that the "look" will fit in with your house.
I kind of like the look. Not your cookie cutter wood stove look. Big old farm house...that look would fit right in.
You are standing at the top of a very slippery slope.....
Engage checkbook
;lol
Enjoy. A new efficient stove is a great investment in my opinion. Keep us informed as you go!
More than willing to open checkbook for a new stove, not so much for propane....
Agree. Completely. LP cost per year is the main reason I started burning wood. Your in WI. Surely you lived through the ridicules LP prices a few years back. Doesn't take long to justify a wood stove!
Trying to find a rear exit stove that has a flue exit height that aligns with the current setup is going to severely limit options. Is there a reason why the current flue thimble couldn't be raised to afford many more choices?
Also, how close is the stove to the Christmas tree?
It was ridiculous. After this winter, I will have saved enough to pay for the wood furnace I just put in.
Reactions: moresnow
It could be raised a little bit, but I would rather not bust out any more bricks than I have to. Yeah, the tree is actually touching the stove. I let the kids put it up. Haven't been using the VC, so no worries. Will be moving it this weekend, cold weather heading our way so I will be firing it up.
WS are only available from them directly, right? No dealers?
Correct. They have a generous trial period and treat their customers well, but the shipping costs need to be taken into account.
If it's not urgent and money is an issue, you may want to bid your time and wait for a wood stove replacement program. For example, an old one in WI is mentioned at: https://www.gagnonclayproducts.com/introducing-the-wisconsin-wood-stove-exchange-program/ . If there's a change in political parties in D.C. come 2020 and a "Green Deal" implemented, I wouldn't be surprised if the Feds start doing some energy related rebates again, like was done 10 or so years ago.
I used a California program to replace my 1980s VC Vigilant, but I had to wait a few years for a worthwhile program to come around.
That said, the old Vigilant could certainly crank out the heat (and eat wood), if I needed to warm the house up quickly. Not so much with the more wood-efficient new stove.
