If you can fit it Id consider the big Kuma, its huge and a catalyctic stove, only problem it requires an 8" liner.
I guess an outdoor wood boiler is not an option for you?
What size chimney liner can you fit in your chimney? That may limit your options.
I have a high valley stove. Its a 2500 model. Its like a 3.5 cuft insert. I pretty much heat my whole first floor in all but the coldest parts of our winter. House only has minimal insulation but modern windows. Its on one side of my home and the first level is about 2500sqft, but the upstiars room is not used and its about 400sqft. Its got dual cats and on mild days can burn 24+ hours, on cold days i run it 12 hours between loads.I do like the LARGE firebox on the Buck 91. I have been calling around today and I can't seem to find any dealers that have sold any of these in over a year. Is there something wrong with them, or are they just not sexy enough for a retailer to keep them on the showroom floor? Seems like the trend is to get away from cats. Looking at the graph that Harman, I would have to say that cats are the way to go, which would limit the selection to BK Princess and Buck 91, unless you all know of another?
(broken image removed)
Those are certainly concerns, and I don't have a great answer yet. Here are some considerations I've had, in order of increasing drasticness (is that even a word??):
1) Having a fan between the family room and kitchen, drawing the warm air out.
2) Running the central heat fan squirrel cage only (the air intake is in the same room as the fireplace).
2) Cutting a hole in the ceiling in the family room (which would be in the floor of the 2nd floor master bedroom in the corner) with a fan inside the register.
If others have a similar setup, I'd love to hear your solutions.
Welcome to the forum DeerHunter.
Only will touch on a couple things as others are giving great advice. Firstly, just think back not that many years when almost everyone, at least in the countryside, heated with wood or coal or a combination of the two. I grew up as the youngest of 4 children and all we ever knew was wood heat. I do not recall anyone ever getting burned from the stove; that is with family and with visitors. Fear of falling and fear of heat seem to be built into the human body and that is good. But if one is that nervous, a fence should do the trick.
On the above, 1). The fan is a good idea but you have it backwards the same as I used to do. You will find that it is better to move the cool air rather than the warm air and that is because cool air is more dense than warm air. So a simple desktop fan (not a pedestal) sitting on the floor blowing at low speed blowing into the stove room will do wonders for moving that warm air into the cooler rooms. Same thing with ceiling fans. I used to do it backwards thinking of blowing the hot air down. Better to suck it up (bet you've heard that phase a few times!).
2) Not too many have had good success running the central heat fan to move the warm air around.
3) Check the codes in your area as registers are frowned on. Check with the fire department too.
Good luck.
If I was going to do it again I would probably go with the BK princess. As much as I like the Lopi for a non-cat insert I still get the cycles of too-cold/just right/too-hot/just righ/too cold which change from wood to wood and from draft to draft. I would hope a cat stove is easier to even out the heat, and would have a larger sweet spot for secondary burning. I like being able to heat a pan on top of the stove, and I love the bypass damper for loading but I'd be willing to give it up for longer, slower burns. It would really be great in the shoulder seasons....And so we get down to the question at hand Should I consider the BK Princess, or does the cat not make up for the smaller box and I should just go with the 3 cuft inserts?
Where is your ductwork located? Inside the insulated space or in the attic? If the ducts are 'inside', the central blower might be useful (and allow you to go to higher BTU), otherwise most likely not.
This has been tried before, the heat loss from the cold ductwork will be significant. We're only talking say 75F air here. Running it through 40-50F ducts often results in more loss than gain. Try the fan trick that I posted earlier. It has a better chance of success.
