Another volunteerPersonally, I would spread the stacks out to let air between, and move out from under the trees.
As you start picking wood, the middle starts to get smallerI've stacked pretty much like that - rows close together, 10 deep, right on the ground, uncovered. Never had any problem with rot at all. Wood that was in the middle burned pretty good but not as good as wood on the top and edges. I have only left it sit two years though.
There is an older gentleman out here who stacks that way and uses PVC drilled full of holes in his pile. He puts in about 15 in a stack like that and claims it dries out really well like that. He's been at it for 62 years. The PVC used to be steel pipes a long time ago he says.I got some plastic to top cover. I know it will take longer to dry, with the dimensions and that doesn't matter, but am I helping or hurting with top covering. It's going to rain later, and I was going to go out there now, in the heat.
Ha, maybe next time. I think velvetfoot can remove every fourth row no problem.It definitely would, you gonna volunteer to help?![]()
Ha Ha, Maybe next time.. I think velvetfoot should be able to take out every fourth row.. No problemIt definitely would, you gonna volunteer to help?![]()
There have been people who have had their wood rot, not sure how 10 rows of wood packed tight is not going to have moisture in the middle for quite some time wihich can lead to rot. People on here sing the praises of air flow and then promply block it.When you got that much wood who cares it will dry
Well I have that much wood and I still stack in single rows all this talk of top cover(single rows really dont need it),and taking 3 years to dry some woods is skewed due to the stacking procedures, its not the best advice for people who are new to woodburning or the ones who dont have the space for 3 years of wood.When you got that much wood who cares it will dry
My point was I DO have that much wood and still stack in single rows red oak, your post reads like I dont have the room, I have read numerous articles about drying wood for fire wood and and lumber and air flow is key.
Top covering is relative to your climate....I can tell you if I hadn't top-covered my wood (single rows, double rows, or 10 rows deep) I'd have been screwed the past couple of seasons...Well I have that much wood and I still stack in single rows all this talk of top cover(single rows really dont need it),and taking 3 years to dry some woods is skewed due to the stacking procedures, its not the best advice for people who are new to woodburning or the ones who dont have the space for 3 years of wood.
Goes against any logic about moisture whether its firewood, lumber or laundry, but I now truly understand why you guys want to dry wood for 3 years, makes sense of the fact that BWS can tell the difference between 2 and 3 year old dead ash.
As a rookie, viewing this photo made me cringe, it is the complete opposite of what all you great guys are trying to teach me...I seem to be moving wood all the time, I would suggest moving some rows out, at leastI got some plastic to top cover. I know it will take longer to dry, with the dimensions and that doesn't matter, but am I helping or hurting with top covering. It's going to rain later, and I was going to go out there now, in the heat.
around 27 FULL cord.....give or take! I'm around 4 years ahead.Beautiful Picture there. How much wood is there?
Very!Strange that at times I've stacked over 20 rows together and have never experienced rot in the wood stacks.
