You would have to try hard to get injured with a battery operated chainsaw,but anything is possible!
I agree completly electric saws can be just as dangerous. The only reason they are any safer is that they have chaon brakes so when you let off the trigger the chain stops right away without the run down of a gas saw. Which is when many people get cut. I know that was the only time i have hit my chaps with a movong chain. Nothing happened but still a stupid mistakeNO. Not true.
A chainsaw no matter how powered can kill without proper PPE AND training and experience..
Chains love flesh.
In fact a non gas saw may not stop because of its torque when hitting the Kevlar threads the same way a gas saw will.
Thats just it the electric chainsaw runs at a low rpm, much lower than any gas powered saw i ever had. Still cuts good. You need to engage two buttons simultaneously to run it plus it has a kick back guard. I cant imagine a scenario where you could get hurt.Any tool that moves at high RPM's like saws, grinders, mowers, etc. can and will hurt you if not carefully handled.
You would get hurt exactly the same way you would with a gas powered saw. If a part of your body comes on contact with the chain while it is moving it will cut you. It doesnt matter if the power comes from gas or electricity. And if the rpm is high enough to cut wood it is certainly high enough to cut flesh and boneThats just it the electric chainsaw runs at a low rpm, much lower than any gas powered saw i ever had. Still cuts good. You need to engage two buttons simultaneously to run it plus it has a kick back guard. I cant imagine a scenario where you could get hurt.
I say I smell a plant.
Well said!NO. Not true.
Chains love flesh.
I think this is a great idea. So good, in fact, I tried it myself. Maybe I got the wrong blades (Vermont brand, looked like bow saw blades), but it was painfully slow.It does not sound like you are going into the deep woods with this thing. If you have power near by, get an electric reciprocating saw. With an aggressive blade it will go through small stuff like do do through a goose, and be safer than either an electric, battery or gas powered saw. Probably cheaper too.
Laugh if you will, but I have been using one for decades on more stuff than you can shake a stick at. Construction, demolition, tree trimming, yard work, metal work, etc..
I use an aggressive Demolition blade for fast cutting rough workWhat blades do you recommend on this setup? Maybe I'll try it again with different blades.
