maple1
I am not sure.
I think he was being sarcastic, a little bit.
[Good luck with this, BTW...]
I am not sure.
I need to remove both warped side panels, which they are going to replace. However, I'm not sure if that's feasible due the warpage.If you remove the screws for the top panel and the 3 on each side of the front panel. That will allow you to lift the top up slightly and pull the front panel off. With the panel removed, look inside and see if you have further damage.
I do have an angle grinder, great idea, thanks. I questioned that once I replace these with the new ones what will guarantee it from happening again. I was told that the newer panels would not warp. This maybe due to the ceramic back which the older model did not have. I would still a very hot base of coals after a 10-12 hr night.Do you have an angle grinder? You could always use a cut off wheel. Even if you replaced the panels, you still have the cracks?
If you haven't already, remove all the outside panels and inspect all the welds. Would be shocked if you don't have a cracked weld.
What is weird is how much the SS warped as there is a sold ceramic brick behind the SS panel. I would have assumed that the ceramic brick would have helped the SS panel hold it's shaped.
Last... when you did have the unit working, were you able to achieve a 12-hour burn?
I am not sure.
No, it is not. The draft motor is still running due to the thermostat calling for heat but that's it. I did reset the pin settings which helped with a little longer burn times.At that 10- 12 hr marker, is the distribution blower still cycling enough to keep the house warm? I can only get a max of 8 hours until the distribution blower no longer can keep up.
This model came with 3 factory pin settings. One for when the distribution fan kicks on, one for when it kicks off, and a safety pin for when it gets too hot.Pin settings?
YesThe high limit controller on the back. I am assuming you lowered the setting for when the distribution blower kicks on and kicks off?
Have you blown it up yet ?Oh yeah, mine is extremely efficient now. Haven’t used this low amount of wood in years. It looks really good on the scrap pile too.
Here are 3 pictures of the fire box.
