I added a damper too my Harman SF-2500-A, and with it closed 100% she still burns wood like a blast furnace. I tried burning wood last night for the first time this season. Last year after having the problem I switched her too coal, and she ran great so I never tackled the wood issue. With the drastic fluctuation we've been having I figured I'd give wood a go again this fall. I added a in pipe damper, and thought I could slow down the burn drastically. Started off with a very small started fire, and all seemed well. When I added larger pieces once again away she went. Door temp hit 600, and stack temps hit 1200, and this was with the damper closed up 100% I had too keep the door vents open75%, or it started too do the dreaded combustion motor sounds it did last year. Would a barometric damper be the next bet on getting this thing under control, and burning smoother?
Chimney spec in 30' with a 6" stainless flex liner.
Thanks, DJinPa
Thanks, DJinPa
