Tried a buddy's Stihl all in one
Throwing all the other sharping files and jigs I have away
It is fast and every thing that needs to be filed is done
all at once rackers and teeth It is even as good or better
than my fancy pro shop sharpener (grinder ) and faster
I don't like wasting my precious time in the woods on sharpening. I cut until noon, and then swap my chains after lunch. I'll sharpen them by the radio in my heated shop one night the following week, using a chain grinder. Grinders can be had for $100 from Northern Tool, which won't heirloom quality, but will get the job done.
Speaking of which, I'm headed to sharpen some chains now. Got a few loops each of 14", 20" and 28".
I guess my post was a little confusing. I cut all day, swapping chains at lunch time on the saws I'm using most, so I can continue cutting all afternoon.I do similar to Ashful. Rarely do i cut past lunch and hand file in field as needed.
Question for you 2in 1 users: are the files in this rig replaceable? Files do wear out, especially on Stihl chain. So can you replace the files, round and flat, in this jig? Or do you drop $40 every season for a new one?
I do similar to Ashful. Rarely do i cut past lunch and hand file in field as needed. Otherwise they get the granberg grindnjoint once wrecked.
You need to take a closer look at chain geometry. The top of the tooth is not parallel to the chain, it is at a negative angle, such that reducing the length of a tooth by sharpening also reduces the tooth height. This is why you need to reduce the height of the depth gauges (called “rakers”, by many here) as you sharpen the chain and reduce tooth length, which is part of the regular process of sharpening any chain.Filing the same on each tooth making a big difference is bs. I always file one side of the chain a little shorter (not on purpose just the way it ends up) than the other and it makes no noticeable difference. They cut with the tip not the length.
I've used a cheap HarborFreight bench grinder in the past, but at the prices that the local Amish chainsaw shop charges and the quality of their work I've brought a few chains to them the last few times.
I was going to pic up a 2 in 1 at the shop today, until I saw the $50 price tag. It can't be that good.
