S
StihlHead
Guest
Correction: That was the Vodka talking. They are all full chisel.
Easiest thing to do is walk into a Stihl/Husky dealer and buy one (relatively inexpensive) sharpening kit for each pitch of chain you work with.
Vice versa (RSC is current AFAIK)![]()
It changed AGAIN this past year. They dropped the "C" from their chain models and are back to RS, RM, etc.
Have a look: http://www.stihlusa.com/products/chain-saws/saw-chains/
Oregon LGX is semi-chisel. Oregon LP and LPX are full chisel.
This is exactly what I use. Pretty simple to use.Easiest thing to do is walk into a Stihl/Husky dealer and buy one (relatively inexpensive) sharpening kit for each pitch of chain you work with.
??? I thought LGX was full-chisel.
http://www.amickssuperstore.com/Oregon_72LGX072G_Chain_p/oregon 72lgx072g.htm
Oregon 3/8 (.375) pitch models offered at Baileys: http://www.baileysonline.com/category.asp?catID=11748
Nope. LGX is full chisel. I have 5 new in the box,2 on the saws right now.
Any one notice a difference between the Oregon files size 7/32" & the stihl 13/64".
OK to use the 7/32 on (3/8 X.050) Stihl RS & Oregon LGX ?
Or is there that much (noticeable) of a difference using 1/64 smaller diameter on the Stihl chain?
Do you vets use a semi chisel chain for wood that's already on the ground , or just sharpen full chisel more often ?
I don't have a loop of semi anymore so I'm just swapping out loops of chisel more often. Gotta fix that, I really liked yellow label RM.Do you vets use a semi chisel chain for wood that's already on the ground , or just sharpen full chisel more often ?
What do ya do if U don't have or forgot to bring a stump vise , just butt saw against somethingI also take a stump vise and filing kit with me, too.
What do ya do if U don't have or forgot to bring a stump vise , just butt saw against something?
I avoid sharpening in the field if at all possible. Faster to swap chains. If you have to, and you don't have a stump vise (mine rides in the case with the saw), then you can clamp the bar in between your feet and work on it like that.What do ya do if U don't have or forgot to bring a stump vise , just butt saw against something?
