Eric Johnson said:
That's a million taxpayer bucks a year--or close to it.
Yup. Now imagine what even halving that could do for a budget. This is a relatively-small town, as well. Larger districts burn even more. Few folks even look at that number.
master of sparks said:
District energy will be making a comeback, I predict. A friend visited a few towns In Denmark last year, as part of an alternate energy tour. They use district heat from garbage burning incinerator.
Then again an engineer friend is replacing the district heat system at a SUNY project with small mod con systems in every building. The underground district system is just is too old and costly to maintain. Maybe underground insulated PE tube is the answer to longevity issues?
Probably an old steam system, I'd guess. Hot water is more initial cost, but tends to be much more reliable, as long as the water quality is properly cared-for, and the efficiency is a lot higher.
For a large system, we'd probably use steel pipe for the mains, and PEX for the branches. When you're pushing a few million btuh, you're talking pipe sizing in the 4, 5, 6" range (and larger) and flow rates in the hundreds of gallons per minute, in some cases. Trying to do that with PEX isn't really practical. It's just a matter of paying attention to the quality of the materials that you use, and to your system design. For example, if you do a row of houses, you put the heating plant tangential to the middle of the row, not at one end. That lets you do the houses as two small loops, rather than one large loop.
If I had the capital to build a development, that's exactly what I'd do. Make a nice "U" road with houses on each side of it, and a heating plant right in the middle. The piping would end up looking like four L's (each L actually being a supply and return), making a general H shape with the heating plant at the center of the horizontal bar.
Very do-able and, while an initial investment, it would be a huge selling feature. Each home's branch would have a btu meter, and they would get a monthly heating bill, just like they might from the gas company or somesuch. Probably for a non-profit to run the heating operation, controlled by the homeowners, to eliminate any concern over price-gouging.
Could also put in a couple commercial buildings on the main road that it connects to, and use the lease revenue to help offset the costs even further.
Anyone know a developer?
Joe
