Hi Folks - We're looking to install an Osburn Horizon in 2-year old home in the fall. The house is two-story 2,800 square-feet finished space, with unfinished basement and attic. We boxed in a space large enough to accommodate the stove on an interior wall dividing the first-floor kitchen and living area with a chase above that area through to the attic. Our local retailer recently visited the house to take measurements. I'm looking for advice on set-up. A few points:
-I've read that these stoves (Horizon and Valcourt Waterloo) perform better with an outside air kit (OAK), but also that it's important to be able to block or partially block the OAK for longer burn times. Can anyone recommend a user-friendly adjustable damper/register, or is everyone just going with the SBI OAK and SBI damper/register?
-The Horizon can be used with a fair number of 8" chimney pipe options. Our installer says "stove pipe is stove pipe." Keeping in mind our chase will run inside the home to a roof penetration (rather than in an uninsulated exterior chase), does anyone have any recommendations on which of the pipe options to choose?
-We'd like to connect the stove to our forced-hot air distribution ducts. Does anyone have recommendations on the requirements for a successful set up? Flexible or hard duct? Standard power in a blower, or go oversized? Connect as close to the plenum as possible, or closer to duct branches leading to rooms we'd like to heat?
-I've read the SBI forced hot air distribution kit is overpriced ($750), and that other manufacturers sell a better, quieter blower, for less money. It certainly looks from the description of the kit as though it would be possible to piece a custom kit together. Does anyone have recommendations on a particular blower?
- Finally, we'd like to install our Horizon about 20-24 inches from the floor, and build a floating hearth seat as our required hearth extension. To do so, we will have to construct the floating hearth seat of materials that meet the R requirements, and tie it in to the stove support framing. We're thinking of cladding the fireplace in durock and porcelain tile, and would make the seat to match. To do so, we'll have to "frame out" the seat, and are thinking of custom-welding a metal stud frame, with arms that tie into the stove support framing. Has anyone does anything like this? How did they build their floating hearth seat and anchor it to the stove support framing?
Thanks in advance for any advice. -Mary
