Secondary combustion tubes not firing
Palentch
3
New Hampshire
Could anyone suggest a reason my secondary combustion tubes do not fire as well as they once did? When I first got this woodburning insert it seemed like they fired a lot better when I fully close the stove. Now when I do that, it seems like they fire much less efficiently and sporadically. I have a Napoleon wood burning stove insert.
Can you describe how it’s hooked up? How full are you loading it? Do you have a moisture meter to check your wood supply?
The most common cause is wood that is not fully seasoned and below 20% moisture content inside. The second issue could be a plugged chimney liner or chimney cap screen. How tall is the liner on the insert?
Reactions: Palentch
Hooked up to chimney liner about 25 ft. It varies how much I fill it. No moisture me
liner is about 20ft. My wood is not as well seasoned this year. I'll try getting a moisture meter.
MC meter will be the best buy you make...
I got my meter at Lowes for around 25 bucks. Its a General, maybe not the best, but she works for my needs.
Poorly seasoned wood is going to cool down the fire a lot as the steam is boiled off. Try adding some dry 2x4 cuttoffs to the fire to see if that helps.
