I have an Encore 2550 tha we’ve used for past 11 years. Cat was replaced this year along with new secondary air probe. I really haven’t had many issues with this stove. Would easily get 9-10 hour burns, sometimes longer.
The primary air cable became disconnected and was fixed by professionals this summer. They adjusted the primary air door and now it does not turn down as much as it should I suspect.
So here is the problem, not every time but sometimes the secondary air probe will get hot enough that it will spin around and start opening the secondary air flap back up. Obviously this is a problem and I’m not sure why it’s happening. Attached is a pic of it open while too hot. Normally it starts at the 5 o’clock position and as the probe heats it’s pushes down and closes the flap. It did that but apparently it kept going and opens it back up. I am at a loss here, I am contacting the pros in the morning but not sure what to do about this air probe. I usually have a heat shield in the back of the stove so it’s not easy to get to.
I will also say the wood I am burning right now is pretty dry, we’ll seasoned.
Thanks in advance for any advice.
![BE5CA0BD-31F7-4B31-9ED1-A8DA9CD530CD.jpeg BE5CA0BD-31F7-4B31-9ED1-A8DA9CD530CD.jpeg](https://www.hearth.com/talk/data/attachments/301/301057-ed03a0874ba85625274ddc514e2870db.jpg)
