Toploader
Burning Hunk
I know exactly what you mean by this, It happened to me twice the first time was just before heading of to bed I closed off the air all the way and immediately the stove started to overheat, I was baffled, I checked all the doors and smoke tested the doors, everything was tight so I got out a fan and pointed it at the stove, this brought the temperature down enough so I headed off to bed totally mystified and bummed out that my reliable Oslo was acting erratically. The second time it happened, again just before going off to bed, I moved the air lever back and forth and when I moved it all the way back to the left again the stove settled right down. The next morning I unbolted the dog house to try and figure out what was happening and sure enough noticed that if I pushed the air control lever too far to the left the plate that closes off the air would ride up over the raised area to the left of the air intake and allow a large amount of air to enter the firebox. Now that I know this can happen I'm careful not to push too hard on the air lever when I'm closing it down all the way, I close it off by gently tapping it until I feel a little resistance. Sometimes the air control is sticky so I move back and forth a couple times to free it up before I close it all the way.Oslo guys, be careful when you close off the air all the way. If you slide it to fast it over travels and lifts up opening up a air path. You can look at it when you open the dog house to lube the slide.
		 Thanks. I'll give that a look the next time the stove is cold!
		 I love this place!
 I love this place!
