after the softwood is reduced to coals
One thing you may notice if your softwood is white pine... it doesn't leave too much in the way of coals.
You can make a simple kiln. Lay down a few pallets in a sunny spot, lay down plastic and poke a few drain holes, stack oak as normal, completely wrap stack in plastic. It will season in about half the time.Yep it's starting to look like pine will become my friend. Helps that a lot of people think you can't burn pine too. Should be easy to get.
Are you checking with the MM on the outside of the splits, or splitting them and checking the fresh split surface?Although there are gains to letting oak season for 2 or 3 years, none of my wood is ever older than 9 to 10 months...including my Red Oak. I wish I could get ahead, but I just can't as I cut all my own trees and it's a lot of work each year getting enough for the 6 months that I burn. If you split oak down to smallish 4" thick splits (which is a big piece for many of the smaller EPA stoves) and stack it in the sun all summer you can be down below 20 % moisture content. It's quite burnable and will give plenty of heat, although it may provide even more if you let it sit an additional year. This year I finally bought a moisture meter and all my wood is below 20% right now, even the last wood I cut and split. It's all about how and where you stack it to maximize the drying time. I never hear an hissing wood in the stove, and get the soapstone top to 500 easy enough. Again, I'm not knocking the 2 or 3 year plan, but it's not the end of the world if you cant obtain that.
[quote="ambull01, post: 1814895, member: 38769 I also have about a cord of oak but I may just leave that stuff in the woods or give it to someone with more patience.
If it doesn't we gonna get real cold tonight. We don't have any other source of heat. And if you haven't noticed, it is gonna be in the teens tonight here. I still plan on sleeping under that one sheet.
75 in the joint right now.
Wouldn't it rot and soak up moisture? Always thought it had to be off the ground.
yes, off the ground... it could be put up in single rows, lying on two parallel logs, in the middle of the woods... just stack it where you drop it. The more sun and air the better, but even shaded it will season as long as it's c/s/s/c.
red oak lasts pretty well even on the ground... the outer inch or so rots and gets punky, but the core stays solid. Maple, on the other hand, rots right through very quickly.
Yes, the ones I tested this year I split open with an axe and tested the fresh side with my meter.Are you checking with the MM on the outside of the splits, or splitting them and checking the fresh split surface?
Minimal meaning doesnt fill up the box with coals and clinkers that take up space for reload (like can be common with under-seasoned wood). Find smaller splits helps keep the pile down also. Leaves a good amount hot and ready for next go!Minimal coals? I thought that was a bad thing. Or are you getting minimal coals because the splits are so small? I would think having coals would be a good thing for reloading.
Okay got it. I'll have to find a nice spot. Found out there's other scroungers around me. It would ruin my day if someone stole all my work.
I'm either going to hold out for a HD 6421 or an older Poulan in 60cc, whichever comes first at the right price. I may be waiting for a long time on the 6421 though. Has it handled everything you wanted to cut?
Well, I wouldn't make a stash of oak except on my own (or friends'/relatives') property... not that property rights mean it won't get stolen anyway.
Got my 6421 for $300, had to call 6 or 7 HDs before I found it... that was about ten minutes work.
Great saw! I do like having my little, lightweight Echo, too, for limbing and cutting branch wood and so forth. Much prefer having one big 20" + one little 14" over having one medium-sized 16-18" saw!
I'm about to stock up on some oak in preparation for next year. I keep reading on this site about having to season oak for 2-3 years. Is this true!?
Seasoning isn't just about months. It's sun, wind, how wood is stacked, whether it's split. I usually re-split the bigger red oak pieces a year after it's in my sunny, hot driveway, and burn it two to four months later. That seems to work fine. If you're talking fat, round logs, yeah, I think three years would make sense.
Oak does take a while, as does hickory. Cherry seems ready after six months if in a dry, sunny location. I usually work a year ahead on everything, and use the oak after January (14-18 months). I refuse to burn anything but well seasoned wood in my urban area; the oak can be well seasoned in 16 months in the conditions mentioned.
This really puts a lot of doubt in my mind on all the "seasoned oak" ads I see. How can everyone possibly have so much oak that's seasoned for 2-3 years?
Pine isn't a hardwood. I should have phrased better. Cherry & Maple are considerd hard woods, although I consider then softer, less dense hard woods as compared to oak, hickory etc.
Poplar is garbage wood to many, I keep it around for shoulder seasons if I come across it. Not for overnight burns. It does dry quickly. Another wood that dries fairly quickly is Ash.
