I’ve been going through some of the older threads on heat pumps and have learned quite a bit- still unsure of some things though...
In Southeastern PA, we heat our 1400 sqft ranch house primarily with a Hearthstone Clydesdale insert. As a backup we have been nursing a 40 year old oil fired boiler, but now that our AC is also ready to be replaced, we are in the market for a new heat pump.
Sounds like any of the two stage/variable speed heat pumps will be great during the shoulder seasons, but we will also need some help in the dead of winter, particularly in the morning after the overnight fire has died. This has led me to look closely at the Mitsubishi line up.
Mitsubishi has the “hyper-heat” technology that allows their heat pumps to deliver heat efficiently at lower temps without the use of electric back up strips. We’re not looking at mini splits though as we would like to use our existing AC duct work for this (if it turns out that the existing ductwork is insufficient, then we may shift our focus to mini splits). There aren’t many options for ducted heat pumps with this technology. Mitsubishi seems to be the only manufacturer to have any available at all. Is this correct and, if so, does anyone understand why?
Anyway it looks like we’re left with either the PUZ-HA30NHA5 which is a 34k BTU heating unit (30k BTU cooling) or a few others such as the MUFZ-KJ18NAHZ which are all around 21k BTU heating.
https://www.ecomfort.com/Mitsubishi-PUZ-HA30NHA5/p80538.html
https://www.ecomfort.com/Mitsubishi-MUZ-FH18NA2/p65203.html
I suspect we’ll need something in between these sizes but I can’t find such a unit from any maker with the hyper heat or equivalent tech.
Does it sound like we’re on the right track here? Should I look more closely at something like the Carrier Infinity line?
https://www.carrier.com/residential/en/us/products/heat-pumps/25vna0/
I’m just scared of the electric resistance backup during the cold winter mornings, and also during defrosting cycles when outdoor temps are below freezing. BTW do those Mitsubishi units even use elec resistance for defrosting??
