The main reasons why I ask is after a typical winter if a vehicle sat over a month without it being run it needs to be connected to the charger to start even with a fresh battery. Didn't have to do that this year because we really didn't get that 1-2 month period of below zero temps. Typically about now I would be starting to connect the charger to every vehicle that sat in order for them to start. I think I only need to do it for my wife’s ATV and my pickup truck this year.
The main question is how does the environment (extreme cold/or heat) effect the operation of an all electric or even a hybrid?
Hi,
I don't know about a full electric car like the Leaf, but were are on our 2nd Prius in SW Montana where it gets down to -20F once in a while. The Prius is parked outside 99% of the time, and we have not had any problems. It has also sat outside for as long as a couple weeks while we were on vacation with no problems.
The Prius holds up to the cold weather better than I do
Gas mileage drops a bit for short trips in the winter, but long trip mileage does not appear to be effected much.
As an all around winter car, the only thing I could really wish for on the Prius is a little more ground clearance.
On the battery maintenance/replacement issue, there are quite are detailed DIY methods out there (one was in Home Power a few months ago) on rebuilding a hybrid battery pack. Basically involved evaluating each cell. Some cells will be OK, some can be recovered with a careful charging process, and a small number will need to be replaced. To me, the process sounded time consuming, but not very expensive. There is an good ebay supply of replacement cells for not a lot of money -- presumably from salvaged battery packs. So, I'd guess, the same sort of thing will happen for full electric cars if the the sales are sufficient.
Gary
