Ssyko
Biglar as you stand in front looking into the hopper. the auger spring, is it turning clockwise and have about a 1/4” clearance from the bottom of auger chute?
Mmm.....stand to the right side - the wiring side - and look in at the auger motor and yes, it's turning clockwise. Yup, just about 1/4" from end of auger to the bottom of the chute/hopper.Biglar as you stand in front looking into the hopper. the auger spring, is it turning clockwise and have about a 1/4” clearance from the bottom of auger chute?
Thanks. I'll paint it and move it back in the shop. I had to replace the side sheets and the back top. What a miserable job but I'll charge accordingly. It's a big bucket. Typical rock bucket, beat the heck.its a flat spring coil with a rounded edge. you cant sharpen it may dig into the hopper wall and damage the chute.
painting: yep you can but take a month to dry unless its above 50![]()
I think you're way out of line.My God,son,none of your problems happened until you replaced your auger motor.Most people would have gotten a clue by now!!
Yes, it's connected to a thermostat, but it sounds like you're referencing a short cycle type of problem. That's not the case. When the t'stat calls for heat, it drops pellets for 30 seconds, the element ignites the pellets, the stove waits for the 200º signal, then starts cycling the auger to maintain pellet flow to give an even burn. It runs steadily till t'stat is satisfied, then cycles off. Flame start up and running size is fine.So you are having to depress the reset button to get it to start. You have the unit connected to a thermostat.
Have you tried disconnecting the thermostat and putting a jumper between the terminals to see how long it would run? Have you tried a different thermostat?
Have you checked in your burnpot to see how many pellets are dropping into it when starting up? Have you tried opening up the slide on the chute to allow more pellets to drop into the auger? This would allow more pellets to feed when it is trying to ignite them. Is your thermocouple adjusted properly? It should touch the ceramic cover and extend about 3/4" into burnpot (if I remember right).
It almost sounds to me that your thermostat is cycling the stove on and off to maintain your temperature. Upon startup, the stove is not dropping enough pellets into the burnpot to be able to start.
I see where you've asked about auger direction and a couple of others, but nothing like this. Not sure what I'm missing here - I've tried to be thorough and clear in my posts, but to get an answer you have to ask a question.I type questions and don't get answers so it is getting difficult to try and pinpoint your issue. i have run your stoves big brother for 19 yrs, cb1200. and its still in my shop. if you look in the pot with a mirror, look for the opening for the igniter. that hole needs to be scraped every time you clean the stove. now you said the stove is clean, ok so the only thing in your stove that creates a vacuum is the combustion blower . if it is original it may be getting tired and slowing down from heat or the fins are beat and not pulling air through the pot to start it. the pathway for air to enter the stove is through the pedistal and goes up through the pot to the heat exchangers and down the back side to the combustion blower chamber through the blower and out the vent. if there is a leak between the pedistal and the blower it can pull air from there instead of going through the pot. now your igniter does not light pellets physically it uses heated air that is pulled through the igniter hole while it is on. so if there isnt enough air being pulled it will not go any further in its programming. the reset button does not trip it is a momentary switch it is in the off position untill you press it then it make a connection until you release it. when you think it trips it is actually the stove not completing its start up, which is due to quick cycling, lack of air, lack of fuel.
