Yes. But I'm on the 3 year plan so it really doesn't matter, it'll be dry. The space savings is more valuable to me.No air space between rows? Does that hurt drying time?
By splitting it on the diameter line first then still considering it a full circle of course.How does one split radially? A cut line from the center to the edge would not separate the round into two pieces.
Got it. I'm rapidly running out of storage space, and looking to build more, but I'll be wanting to burn some of the wood in the 24/25 season. I've got easy access to lots of free pallets, and pallet-based storage is easier to build than more substantial sheds. But an air gap between rows means dropping down to two rows, which takes more total land space, and would get in the way of future shed space.Yes. But I'm on the 3 year plan so it really doesn't matter, it'll be dry. The space savings is more valuable to me.
A-ha: a hidden assumption. It really isn't a radial split, it's a diameter split. (Yes, I already knew thatBy splitting it on the diameter line first then still considering it a full circle of course.
)I've historically done 2 x 1 cord interlocked stacks and they worked well for me. I could season any non-oak or locust wood in 1 year. I'll attach a picture. The flaw for me was my storage area is low laying and very soft in the spring, first heaves in the winter. The tremendous weight on the cinder blocks would cause a lot of settling. There's absolutely nothing worse than restacking 2 cords in the middle of mud season.Got it. I'm rapidly running out of storage space, and looking to build more, but I'll be wanting to burn some of the wood in the 24/25 season. I've got easy access to lots of free pallets, and pallet-based storage is easier to build than more substantial sheds. But an air gap between rows means dropping down to two rows, which takes more total land space, and would get in the way of future shed space.
Almost all of my wood is easier-to-dry PNW softwoods. Not yet sure if I can dry softwoods in a year in three-row stacks without a gap between rows.
 learn something new everyday.now i'll have to go impress someoneNo, it's still termed "radial". Radial simply refers to any ray, vector, or line intersecting the center of a circle.A-ha: a hidden assumption. It really isn't a radial split, it's a diameter split. (Yes, I already knew that)
The side pallets are screwed down directly into the ground pallets they are on and the vertical backs with some exterior construction screws. Then I have 4x4 runners on the ground to help prevent wobble. The middle vertical pallets are largely supported by the wood itself though. The end ones I added an extra cross brace 2x4.@Caw Nice setup with your pallet wood racks. How do you support the vertical side and back pallets? Looks like some chunks of 4x4 in one picture for the sides, but what about the back?
Wish we had some of your snow!
Note the smiley in my post.I can't believe this has even become a debate.
You're doomed! Or blessed.Ok ok ok...geometry war is over.
Btw I asked my wife to make a secant split the other day for fun and she smirked at me then did one perfectly. Son of a B.
I'm fully aware she is smarter than me when it comes to school stuff. Since we have the same degree and are in the same profession it's easy to compare apples to apples. She's also great with and loves numbers so she handles the finances which makes my life easy. I bring other talents to table such as the wood burning, construction/remodeling, cooking, etc. So we make a pretty good team.You're doomed! Or blessed.
Actually, probably equal parts of both.
Yeah I was thinking the same thing. I made sure they are strapped down well and threw a pallet on top of each stack for extra protection. I'm out of heavy things to put up there so we'll see if it's good enough.Good time to check the tarping technique. Up at my place they are predicting 40 to 50 mph winds.
Fist Pump for your wife! That's awesome.Ok ok ok...geometry war is over.
We actually discussed all the other cuts we were talking about earlier afterwards seeing what we could remember from geometry lol. It was a good time.Fist Pump for your wife! That's awesome.
What's even better is she resisted the urge to say "Is that all you got?"
Does your brain still automatically snap into a cylindrical coordinate system?We actually discussed all the other cuts we were talking about earlier afterwards seeing what we could remember from geometry lol. It was a good time.
Making imaginary cuts could be interesting.Does your brain still automatically snap into a cylindrical coordinate system?![]()
I always try to get my racks all filled up in spring, which is always a challenge, given my access to the wood lot is across some pretty soft and soggy ground, when things thaw in spring. I try to pack in the several dozen tons of logs while things are frozen, as my only other chance is in the July heat and dry hard ground.I'll try to jam in 2 more cords before golf season starts.
