ashley aw1820e, a us stove productWhat stove? I haven’t seen any for todays more modern EPA stoves having that option but maybe you could retrofit something from a sauna stove manufacture or wood cook stove. I know my Nippa sauna stove has a side water tank option.
Isn't that an insert? Is it being used outside of a masonry fireplace or is three just a lot of room around it? I don't this idea will work well due to the convection jacket around the stove.ashley aw1820e, a us stove product
it is the insert model. the convection jacket is only in from the bottom, around the back, and thru the top. the lower sides are not part of that jacket and the lower portions of the side between the removable baffles are available. the very top also gets hot enuff to boil a kettle. I am not looking to boil water, only to move some heatIsn't that an insert? Is it being used outside of a masonry fireplace or is three just a lot of room around it? I don't this idea will work well due to the convection jacket around the stove.
in your house, perhaps.Wouldn't it be much easier to add airflow fans thru that space?
convinced to satisfy you or for my house?I am not convinced that adding a reservoir on the outside is going to be able to transport a decent amount of heat.
I am simply adding, not relying on this. I have a navien natural gas tankless water heater for that. I also have insulated storage tanks.Whatever.
It's unlikely you'll get a constant (slow) stream of 120 F from reservoirs on the outside of your insert.
Go ahead, expend the energy and money. Be prepared to be disappointed.
It's not going to work it either isn't going to transfer enough heat to make a difference. Or if you get good heat transfer it will lower the firebox temp too much and you will get creosote buildup. This insert isn't designed to be a hydronic heater.convinced to satisfy you or for my house?
again, many here think I only have wood stove. I have insulated storage and a natural gas tankless water heater. I can do more than one thing, if that was what you were thinking. putting warmer water as input into my tankless is better than putting in cold water straight from the pipes undergroundIt's not going to work it either isn't going to transfer enough heat to make a difference. Or if you get good heat transfer it will lower the firebox temp to much and you will get creosote buildup. This insert isn't designed to be a hydronic heater.
your advice is based upon your house. thanks, but I will simply assume you didn't know enuff about my application to commentMy point is that you asked for advice. You got it but don't like it. Have it your way.
I asked not about the worth. I asked if anyone knows where something can be obtainedWay to ask for advice, not telling the whole story...
It'll still not be worth the effort.
It would have to be custom made I am sureI asked not about the worth. I asked if anyone knows where something can be obtained
I have lined up a fabricator to weld up using stainless already. I just wanted to know if this was common or if there was an outfit that already has these fabricated that I can buy off the shelf.It would have to be custom made I am sure
for me, yes. as in insert for others, hard to say. I don't know the box they started with before getting their insert in, so I can't speak to that.Definitely not common. Is there room in the fireplace for these tanks alongside of the stove?
there is not any way to just haul a wood stove downstairs. there's no where to put it down there. I have radiant floor, why not just tie it in?Sounds like it's set in a large fireplace. Seems like it might be a hassle to plumb and not have the wife upset. There needs to be a thermal expansion tank, temp/pressure relief valve, pump, etc. This is much easier with a freestanding stove that doesn't have all the surrounding masonry in the way. What about putting a wood stove downstairs and using that to heat both floors?
So you have an insert in a gutted zero clearance fireplace????? You do realize how dangerous that can be right? This is getting worse and worse.there is not any way to just haul a wood stove downstairs. there's no where to put it down there. I have radiant floor, why not just tie it in?
I would be thrown outa my own home if I tried. it's a smallish cabin.
the fireplace is encased in zero clearance sheet metal layers, 2 gapped layers. the stove pipe is standard lowes selkirk supervent stainless double wall, 4x 3ft sections.
for the plumbing ports, I will step bit the plumbing holes right thru that sheet metal, just like the holes that were there when gas lines penetrated thru those holes. I will come in from the outside and use flexible corrugated stainless lines to pipe that in and out
it works, and the side never heats up to where I can't put my hand on it. you need to stop stalking me and relax, modSo you have an insert in a gutted zero clearance fireplace????? You do realize how dangerous that can be right?
