Unlike most posters on this site, I did do a search but basically came up with zip. I need to move my RV from where it is (next to my shop, plugged in to shore power) to a basically remote location near my hunting property in northern Michigan. The RV will sit on a friend's property next to his barn but so I can access it for lodging during hunting trips and as a 'garage' if you will, for my quad which I will use to travel my property.
While I can shore power the RV via extension cord to his barn, I prefer to run self contained for the most part. I will have my Yamaha Inverter generator with the camper so that if my wife and I want to go up in the summer, we can run the roof ac, however, most times it will be minimal power usage except keeping the Quad battery charged and using the 12 volt power for interior lights and the fridge (propane/12volt) when we are 'staying' in the camper for hunts. The propane furnace is also 12 volt powered.
I run a pair of Group 31's, 1000 CCA flooded cell batteries and the RV is pre wired for an on roof array but has no charge controller and no panels. The install will basically be flat on the roof but the camper will be sitting in the open with no shade.
I'm not going to be there every weekend but I need the panels to keep the house batteries charged and my quad's battery charged and of course the CO detectors and the on board electronics operating and, it gets cold here too.
I won't be using the plumbing and the tanks will stay drained and winterized. If I need to use the 'facilities' I have 120 acres of woods all about.....
I'm thinking that a simple charge controller nothing too fancy and a single large panel would handle the electrical needs but I'm not sure and I need some guidance. I can do the install myself, just need to know what I need to get it operational.
Thanks in advance. I need all the advice (preferrably good advice) I can get.
