Mod Edit: Discussion moved to new thread
Mansfield II 8012 model had a measured emissions rate of 2.8g/h and 68% HHV efficiency
Mansfield III 8013 model with the Hybrid combustion measures 0.54g/h and 78% HHV efficiency
When wood gases and oxygen are burned in a cat, that is an exothermic reaction. Your statement implies that hearthstone has found a way to operate a cat in a manner that burns off combustible gases without generating any additional heat. Not only does that not make any sense, the numbers prove otherwise. This stove design benefits significantly from the addition of the cats. The amount of combustion that takes place in the cats on this stove, when operated "normally" (at recommended settings) is a lot less than in a dedicated cat-stove, but it was enough to take this stove from 20 years ago ordinary to one of the most efficient and clean burning stoves on the market.
In my experience, when the Mansfield "Tru"Hyrbid (marketing wank) stove is choked way down, the secondary combustion will shut-down after 2-3 hours slow-flaming, but the wood is still fairly rich with wood gases, at that point a point fuel that would have gone up the chimney unburnt begins to burn exclusively in the cats. The cats start going tink tink tink and the temperate probe over the cat shoots up higher, causing the soapstone's and cast pieces up near the back corner of the stove to heat up (confirmed with IR gun), and also causing the EGTs to go higher, which is part of why I believe this stove works better with some single wall above it. When the cats are really cooking right below the exhaust collar its good to have a way to extract a bit more of that heat into the room to take advantage of that "phase" of combustion on these stoves.
With that said, the Mansfield is not well optimized to operate like a wood gasifier/cat-combustor the way the BK/Woodstock stoves are. The cats in this design are just sorta sitting there on a plate, they don't have a good way to conduct heat into the surrounding materials, so it's mostly radiated heat and higher EGT's up for grabs there. It doesn't perform as well when operated this way and that method of operation is discouraged in the manual. I've played with it on a few cycles, and yea, the cats will light off and get super hot but it's not as clean or efficient running this way as it is with active secondaries. The cats on this are not as fine a mesh as found on other systems, and the catalyst material chosen is something simpler/cheaper (supposed to be lifetime cats). It works best when operated with the air intake about 1/4-3/8" open as indicated in the manual, which results in steady secondary combustion lasting through almost all of the wood-gas release phase of the burn. When operated this way the cat just picks up the slack that secondary combustion misses both during active secondaries and for awhile after flames drop-out in the firebox. At these settings the stove can deliver slightly slower burn rates, slightly cleaner emissions, slightly longer burn cycles, and slightly better thermal efficiency than you'll get from a non-cat stove. If the cat was "only cleaning up the exhaust" then it wouldn't have gained 10% efficiency with them added (actually from 68% to 78% represents a 15% "improvement"). Combine that with the greater thermal mass and it all adds up to a more drawn-out heating cycle that is more usable and comfortable for most milder days of the year and fringe season heating. I can get 8-12 hours burn cycles on Ponderosa with 9% moisture. There are plenty of people burning hardwoods in non-cat stoves with similar burn cycles so I think the cat is more useful in this application than just cleaner exhaust.
